Audio levels in HG10 - any control? at DVinfo.net
Old October 27th, 2007, 08:41 AM   #1
Is there any way to control the audio record level when using either the built in or an external mic on the Canon HG10? I've looked through the menus and the manual and haven't seen any user adjustable settings. Thanks.
Len
Len Rosenberg is offline   Reply With Quote
Old October 27th, 2007, 08:45 AM   #2
Unfortunately no. The HG10 has a microphone input jack but it does not allow for manual control of audio input levels.
Old October 27th, 2007, 10:06 AM   #3
Thanks Chris.
Old October 27th, 2007, 03:02 PM   #4
Moved from HV10 / HV20 to AVCHD.
Old October 30th, 2007, 12:07 AM   #5
Hi there,
I have the HG10 and here's a few workarounds,
1. Use a Beachtek
2. Use a ghetto little headphone attenuating cable and experiment with dialing it back
3. Small field mixer
Here's a clip I made tonight with a Rode Videomic and my little cable solution. The average volume with it at 100% and 50% is similiar, but the 50% version has less limiter kicking in. I could have dialed it a down a lot more if I had needed to.
http://www.seanmccormick.biz/outbox/...videomic_w.mov
I have a Beachtek if I want to use my AT4073a shotgun mic. The Rode's nice for simple stuff as it doesn't require a separate phantom source.
Len
Sean McCormick is offline   Reply With Quote
Old November 3rd, 2007, 01:42 AM   #6
Duh moment...
I just discovered the newer version of the Rode VideoMic has a battery compartment-located dipswitch that allows attenuation levels of 0, -10, -20.
Old February 12th, 2008, 04:55 PM   #7
Dammit. That's a stupid move... one of the features I REALLY liked about the HV20 was the fact that you COULD control the audio input... helped me to avoid audio blowouts.
Yeah, yeah, I know, Beachtek adapter, but still.
Brian Boyko is offline   Reply
