Avoid Freeze frames when Capturing 24p at DVinfo.net
Old September 26th, 2007, 06:26 PM   #1
Greetings from Colombia (South America!) You might all know this already but as Im constantly asking questions here, I thought I'd drop a little info I discovered today. A tip really.
When shooting 24p, if you record something and then go into play mode to check it out make sure that you stop the tape 6 seconds before the end of the final shot bofre going on to shoot more otherwise you get a nasty freeze frame that mucks up the capture process, in vegas anyway.
There you go. Have a good day. Ben
Ben Hillier is offline   Reply With Quote
Old September 26th, 2007, 07:23 PM   #2
I just do END SEARCH and it works very well.
P.
Pedanes Bol is offline   Reply With Quote
Old September 26th, 2007, 11:48 PM   #3
Stripe your tapes.
Dennis Khaye is offline   Reply With Quote
Old September 27th, 2007, 08:05 AM   #4
Originally Posted by Dennis Khaye View Post
Stripe your tapes.
For a newbie, what does this mean?
Jim Browning is offline   Reply With Quote
Old September 27th, 2007, 09:55 AM   #5
Are you saying to just write over the last 6 seconds of your 24p video? I think I was innerspersing some 24p with other settings one time and I wound up with 3 tapes that after watching them one time, I was never able to play them again. They all would freeze right away. I could see the video if I fast forwarded though. I guess once you have this problem you can kiss the tapes goodbye as for as getting to capture anything from them.
John Hotze is offline   Reply With Quote
Old September 28th, 2007, 09:18 PM   #6
Stripe your tapes = put a new tape in, leave the lens cap on and hit record. Let it record to the whole tape. Rewind and use as normal.
