HV20=>HDMI=>MacPro&Intensity at DVinfo.net
Old September 26th, 2007, 12:14 PM   #1
HV20 Sample footage directly to MacPro 2x2.66GHz 8GbDDR2 wiht Intensity via HDMI(10m) in FCS2 ProRes422(HQ):
http://rapidshare.com/files/58404997...ov.part01.sitx
http://rapidshare.com/files/58380708...ov.part02.sitx
http://rapidshare.com/files/58389665...ov.part03.sitx
http://rapidshare.com/files/58396555...ov.part04.sitx
Svyatoslav Pylypchuk is offline   Reply With Quote
Old September 26th, 2007, 01:34 PM   #2
Svyatoslav, can't check out your clips since I'm not on FCS2 but have been really wanting to see some HV20 Intensity footage. I'm wondering if you could post some footage in another codec such as Photo JPEG (quality set to 75% or better)? I would check out http://www.mediafire.com/ for free file sharing also, it doesn't have the limits that Rapidshare has.
Clips | Stills
Wes Vasher is offline   Reply With Quote
Old September 26th, 2007, 06:16 PM   #3
Ok! I will do it, does not think although, that Photo JPEG is a good codec.
Sense was exactly in that, to show work of ProRes. Can it be better to save now without encoding?
Recently did a trick - created a virtual disk in memory and wrote down straight in it via HDMI by Blackmagic Media Express: UNCOMPRESSED.
I was shocked - 1G/s. Phenomenal quality.
Now I will give a grand-dad my Cinealta :) I will shoot the next commercial straight in memory by two HV20 and Blackmagic On-Air 2.0.
Wes, please, how you do it:
"Converting 60i to 60p
1440x540 effective resolution 60p footage can be extracted from a 60i 1440x1080 stream by de-interlacing 60i footage and preserving each field as an individual frame." http://www.vasher.com/v4/v4_more.php?id=98_0_3_0_M4
P.S. If interestingly, look here:
http://www.dvinfo.net/conf/showthread.php?t=104242
Old September 26th, 2007, 09:26 PM   #4
Svyatoslav, Photo-JPEG is a very good as long as you compress to a quality setting of 75% or higher. Good for posting high quality clips at reasonable sizes. I only suggest it because not everyone has FCS2. :(
If you shoot 60i you can seperate each field and make that into a frame, thus getting lower resolution 60p video from your HV20 (or any other 60i camera for that matter). Which is good for slow motion and other effects.
Clips | Stills
Old September 29th, 2007, 03:03 PM   #5
HV20 1/48 => HDMI => Apple ProRes422(HQ) => Motion JPEG 75%:
http://rapidshare.com/files/59067212/sheva2.mov
unfortunately in mediafire.com I can not insert more than 100Mb too
Old October 1st, 2007, 08:59 AM   #6
Svyatoslav, outstanding shot! The cigar smoke would really challenge the MPEG2 compressor but the Intensity capture just looks silky smooth. Great job and thanks for posting the clip. Was this in TV mode?
Clips | Stills
Old October 1st, 2007, 04:10 PM   #7
Thanx. Yes, Tv mode 1/48.
Only one trick: I used a polarization filter, to reduce the specks of light on the skin.
Old October 1st, 2007, 05:31 PM   #8
This is great to see! Proves how much nicer pure 4:2:2 is compared to 4:2:0.
I've captured raw 4:2:2 out of the HV20 too, but used a 35mm adapter, so it's nice to see this uber-sharp pure footage. Thanks for sharing!
Mac + Canon HV20
Robert Ducon is offline   Reply With Quote
Old October 2nd, 2007, 05:44 PM   #9
Very nice. Really shows how badly HDV mucks-up what the sensor is capable of capturing. Just reinforces that I'm going to have to shoot tethered. :-(
Joseph H. Moore is offline   Reply With Quote
Old October 2nd, 2007, 05:48 PM   #10
PS. Do you think you could post an uncompressed, full-res still? (PNG, TIF)
Old October 2nd, 2007, 06:21 PM   #11
I will shoot movie specially for you tomorrow.
Uncompressed :)
Old October 3rd, 2007, 12:01 PM   #12
Here a few movies by duration of 1s. Written down in RAM and HDD by FCP and BME(Blackmagic Media Express). UNCOMPRESSED. It is initial files and it's necessary to do pull-down and deinterlacing. Weather terms are bad although, but quality is visible:
http://rapidshare.com/files/59996077...4toHDD.mov.zip
http://rapidshare.com/files/59997960...4toRAM.mov.zip
http://rapidshare.com/files/60000006...0toRAM.mov.zip
http://rapidshare.com/files/60007339...4toHDD.mov.zip
http://rapidshare.com/files/60012353...0toHDD.mov.zip
Old October 3rd, 2007, 01:11 PM   #13
Many thanks!
Old October 3rd, 2007, 04:38 PM   #14
I hope that Canon and Blackmagic will give me a medal :)))
Old October 3rd, 2007, 05:38 PM   #15
The detail is just phenomenal. So clean. If this camera had true manual controls, it would be an indie dream machine.
