#16 |
Contributor
it's hard to tell because the places we were had so much ambient noise, but from what i can tell there is less noise when using the controls than the hv20, just by the fact that they are mounted on the lcd, there is no tape drive noise, and the harddrive is very quiet, and in the clips i have i can't hear the hdd or the zoom motors, but again there is a lot of ambient noise. this cam also is a bit more solid in your hands than the hv20, the lack of a tape drive means no tape drive door, which eliminates the slight play that the body of the hv20 has which in my experience causes some noise when you adjust your grip etc..
some audio (after saying the settings i was pushing buttons changing exposure etc...) http://file.meyersproduction.com/hg10/hg10%20audio.aif |
#17 |
Thanks a lot. It seems there's no tape noise in that recording (little bit difficult to tell with the sounds but I usually still would pick it up).
Sounds promising:-). I guess the lack of audio volume control is not an issue if I don't need to lower it to reduce the tape noise:-). |
#18 |
Where to buy?
By the way where did you buy it? Looking at [non-sponsor reference removed] it says ships in October?
#19 |
That's right, it's not available until October. He didn't buy it -- he had his hands on it only for a short while. See http://www.dvinfo.net/conf/showthread.php?t=100722
#20 |
Actually it has an audio volume control. That's what adjusts the audio volume when playing back pre-recorded video clips. What it doesn't have is manual audio level control over the built-in mic or the external mic input, for manually adjusting the incoming audio levels during recording.
#21 | |
#22 |
Well, users of the Vegas editing software will be disappointed. I have verified that Vegas 7 won't edit these files...just like Vegas won't edit Panasonic AVCHD...thanks Austin for posting the raw video. Plus, Sony has announced Vegas 8 to be shown at IBC won't edit any AVCHD except Sony's version.
#23 |
I was debating between the JVC Everio HD, and the HG-10, and your clips sold me...I don't know why Camcorder Info said the 24P was unusable, it looked fine to me...maybe theirs was defective.
Also, I saw that your 24P clip was a 24 Frame file, not 1080/60i with pulldown...did Final Cut do that upon import or did you use a workaround (if so, what was it?). |
#24 | |
In respect to the codec quality, this is the best AVCHD compressed footage I have seen up to now. I assume this is the first camera on the market which provides AVC encoding up to 16 MBPS. If the next generation of single chip AVC codecs support the full AVCHD specification (current limit is 20MBPS), the AVCHD format becomes also interesting for prosumer camcorders, replacing HDV and maybe even XDCAM MPEG-2. |
#25 |
#26 |
Contributor
it said 15mbps in the camera's menu...
#27 | |
Contributor
My work around for 24p is I batch encode using compressor 3 (FCS 2) to remove the pulldown. The HG10 was a bit different as when I initially captured it in RroRes and then tried to remove pulldown and re-export it to ProRes, I was getting some funky errors, so I would have to capture to AIC and then convert to ProRes removing pulldown or vice versa. On the hv20 I capture to 60i HDV and then export it to HDVp24. |
#28 |
Contributor
imovie 08
imovie 08 works with the HG10
http://file.meyersproduction.com/hg1...20settings.png http://file.meyersproduction.com/hg1...e%20import.png It's quite the interesting little app... it also captures and transcodes to AIC at about 90-95mbps at 1440x1080 or 960x540. the coolest part next to the ability to just scrub through your video on the fly is the iphoto-esque image adjustments, and they playback real time (at least on my macpro) |
#29 |
#30 |
Heinz, i have sample from Panasonic AVCHD cam with these parametras:
file type : TS video stream type : AVC/H.264 resolution : 1440x1080 profile:level : Main:4.0 aspect ratio :30x17(Extended_SAR(4:3)) interlaced : yes frames count : 278 frame size max : 446 208 avg : 63 558 avg/max (I) : 221 962 / 446 208 avg/max (P) : 66 094 / 148 992 avg/max (B) : 39 526 / 91 392 min : 17 856 file size : 17 670 144 -------------------------------------------- framerate declared : 29.97 -------------------------------------------- real : 29.97 bitrate declared : 16 000 000 -------------------------------------------- real max : 28 046 968 real avg : 15 239 430 real min : 11 609 213 Interesting is comparing GOP of samples from Panasonic AVCHD and Canon HG10. Panasonic (from samples i own) have variable GOP from 12 to 16 and looks as IBPBPBPBPBPBPBPI... HG10 sample 00011.MTS always have GOP15 as IBBPBBPBBPBBPBBI... Max bitrate at 28Mbps is good for complex scenes:) Austin, all of *.mts samples is 24p inside 60i ? |
