HV20 Hot Shoe Handle? at DVinfo.net
Old August 7th, 2007, 05:13 PM   #1
Does anyone know where I could pick up a carrying handle that slides onto the hotshoe on the camera?
Brian Tori is offline   Reply With Quote
Old August 7th, 2007, 07:35 PM   #2
I've never heard of that, but I bought a flash handle that I attach to the bottom of mine. With a little effort you could probably make your own too..
Here is a link to the handle I purchased.
http://www.bugeyedigital.com/product...bow-va313.html
I am pretty happy with it, but be warned- I tried to reverse the plastic grip handle and the indentation in the handle for the hex nuts and bolts broke apart. I now have only half the handle attached as the other half was ruined.
Still, it is inexpensive and works for my needs. I plan to find a way to mount a shock mount and mic where the flash would normally go.
Brandon Svec is offline   Reply With Quote
Old August 8th, 2007, 11:34 AM   #3
I have 3 different L Brackets like this, including this one. I like this one the best. I also took the handle off, but to remove that strap.
Having a handle out to the left of the LCD is awesome, but I would also like to get a top-mounted handle that attaches to the flash/accessory shoe. Anyone else know of anything?
Chris
http://dewde.com/videos
Chris Ames is offline   Reply With Quote
Old August 8th, 2007, 02:20 PM   #4
I don't think I'd attach anything to the hotshoe - doubt it's structurally solid enough... there's a guy on Ebay selling something he calls the scorpion - it has a baseplate with feet, and wraps up and around the back of the camera to a handle on top - search "steady cam" to find the bazillion he's got listed. Looks sorta like what you're asking for, and I've seen a couple different variations on this idea... this one is inexpensive, might be worth a look for you?
I too use "L" brackets - two, mounted to a flat bracket, one to each side of the cam, for a mini figrig...
Old April 17th, 2013, 06:41 AM   #5
Re: HV20 Hot Shoe Handle?
CINEIK Hot Shoe Handle - cineik
Laurence Kingston is offline   Reply With Quote
Old April 18th, 2013, 01:33 AM   #6
Zacuto Cold Shoe Handle| B&H Photo Video
Mark Watson is offline   Reply
