first consumer 1/2 chip cam at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > Canon Optura Junior Watchdog
High-end affordable consumer 1-CCD camcorders. PAL users invited!
Old July 29th, 2005, 07:42 AM   #1
Skyonic New York
the optura 600 really came out of no where, the fact that it has a 1/2.8 chip gives hope to a 1/2inch chip xl3 or even gl3...below gives you idea of how much resolution that sucker must be pulling, and it should be a low light king as well
optura 60 wide mode pixels
1/3.4-inch CCD
1,230,000 pixels
optura Xi
1/3.4" CCD
2,200,000 pixels (approx. 1,230,000 effective pixels-tape
canonxl2
1/3"
680,000 pixels (total)
Sony HDR-HC1
1/3" 3000K Pixel CMOS Sensor
1983K Pixels (16:9); 1486K Pixels (4:3)
optura 600
1/2.8 -inch CCD
approx. 3,500,000 pixels (4:3)
approx. 2,990,000 pixels (16:9 IS* OFF)
approx. 2,740,000 pixels (16:9 IS* ON)
3,500,000 pixels is just sick on 1/2.8 inch chip, noise should not be an issue any more either, i guess...to bad the rest of the spec on the cam aren't up to snuff
no optical stabilization, small lens, no manual mode...
Robert Mann Z. is offline
Old July 29th, 2005, 08:17 AM   #2
Well chip sizes like 1/3", 1/4", etc. are pretty hard to get your head around because they aren't actual measurements of anything. Originally this dimension refered the the diameter of a cylindrical vacuum tube in old cameras but was later applied to solid state sensors with image areas comparable to 2/3" diameter tubes. So numbers like 1/4.7" and 1/2.8" are really just made up by the manufacturers and you would need to see actual chip dimensions to understand them.
However, putting this all aside just for the sake of argument, 1/2.8 = 0.357 and that is a lot closer to 1/3" (0.333) than it is to 1/2" (0.500) so it's kind of a stretch to call that a 1/2" sensor.
Also, is it native 16:9? If not then you would be letterboxing to shoot widescreen which reduces the effective area of the chip. I'm not really knocking the camera at all, and it is great that they're using a bigger chips. Just pointing out that 1/2.8" isn't a whole lot bigger than 1/3".
Boyd Ostroff is offline
Old July 29th, 2005, 09:24 AM   #3
Skyonic New York
whenever some says something like "I'm not really knocking the camera at all" it means they really are, it falls under the same pretense as "i don't mean to offend anyone, BUT" means there just about to offend someone or the ever popular "to be honest with you" means there just about to lie... :)
actually i think the camera is so so but the increase chip size is somethingt to get excited about, if you feel this stuff trickles up from time to time...
1/2.8 is not a 1/3 chip its bigger if ever by a fraction, its a good move for the industry and keep in mind this chip is not in your new scuba cam or an xl2 its in a soccer mom optura...
the chip doesn not appear to be 16:9 native which is why you would get more pixels 4:3 then 16:9, but who cares neither is my semi pro dvx...
Old July 29th, 2005, 09:45 AM   #4
OK, OK, point taken :-)
I just think calling 1/2.8" the "first consumer 1/2 chip camera" is a bit of a stretch. Based on other discussions around here, those strange fractions confuse people. In the case of a 1/4.7" chip, many see the 4.7 and note that it's bigger than 4 so they assume the chip is larger than 1/4" when it's actually the other way around. I suspect the camera manufacturers are hoping you'll do exactly that...
Agreed though: bigger chips are certainly a step in the right direction - bring 'em on!
Old July 29th, 2005, 10:50 AM   #5
Considering it's an Optura I'd imagine it's real 16:9.
PAL shooter in NTSC territory
Patrick Jenkins is offline
Old July 29th, 2005, 01:13 PM   #6
I'm sure you're right about that. However many (if not most) cameras use a chip which is native 4:3 and sample 16:9 from a letterboxed area within it. As long as the chip's pixel count is high enough (which it certainly is in this case) you still get real 16:9. But my point was that you aren't using the full surface area of the chip, so it will be similar to using a smaller CCD.
On the XL2 you have the opposite situation. The chip is 1/3" native 16:9, so if you shoot in 4:3 mode it's more like a 1/4" chip.
Old July 29th, 2005, 09:00 PM   #7
Skyonic New York
there is a picture of the chip on japan's web site, its a 4:3 chip, i know canon did not make this chip, i wonder who did sony? panasonic?....
Old July 30th, 2005, 07:37 AM   #8
Guys, the nature of your various comments here makes me think you haven't read my laboriously prepared Optura pages!
http://www.dvinfo.net/canonoptura/index.php
Notes on Optura CCD sizes: http://www.dvinfo.net/canonoptura/ar...eage.php#opccd
Canon never reveals their source for CCDs. Personally I think they missed the boat years ago by not getting into CCD production, and it's too late now.
Chris Hurd is offline
Old July 30th, 2005, 02:10 PM   #9
Built the VanceCam
Originally Posted by Chris Hurd
Chris,
I think you should go one step further in your conversions, for comparison with standard actual CCD diagonals:
2/3": 11mm
1/2": 8mm
1/3": 6mm
1/4": 4mm
With the oddball fracto-decimal-thingys, the actual diagonals are probably being fudged by the manufacturers, but we can assume the true diagonal is about (but no more than) 70% of the given chip measurement.
That gives us:
1/2.8": 6.3mm
1/3.4": 5.2mm
1/3.9": 4.6mm
In descending order for easy comparison:
2/3": 11mm
1/2": 8mm
1/2.8": 6.3mm
1/3": 6mm
1/3.4": 5.2mm
1/3.9": 4.6mm
1/4": 4mm
Dan Vance is offline
Old July 31st, 2005, 09:02 PM   #10
I always assumed the CCDs were getting larger just to accomodate the millions of pixels. I don't really think you can have a native 4MP CCD and have it smaller than 1/3". Just take a look at 4MP digital cameras and you'll see what I'm talking about as they all have 1/2.5", 1/2.7", and 1/2.8" CCDs.
As for low light performance.. It requires a large CCD, low pixel account, refined DSPs, and of course a quality lens. The VX2100 is a great example of all of these.
Tommy Haupfear is offline
Old July 31st, 2005, 10:50 PM   #11
Built the VanceCam
I think that's true. They are pretty much at the low limit for pixel size. From what I've read, minimum practical pixel (CCD well) size is about 2 microns. And the minimum space between pixels is the same, since you have to have a place to transfer the charge to. If you calculate that out, a 4MP 1/3" chip would be past that limit. Pixels smaller than 2 microns would have poor sensitivity, plus they would be getting uncomfortably close to the upper wavelength of visible light (0.7 microns).
Old August 24th, 2005, 05:24 PM   #12
Chris, thanks for the Optura pages !
I'm shopping around for a 2nd small camcorder as my 1998 little JVC died
recently. I'm looking at the Sony HC90, Panasonic PV-GS250, Canon Optura60. Thank you very much for all of that Optura information, as there is more info that I haven't seen in the other on-line reviews.
Gints Klimanis is offline
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > Canon Optura Junior Watchdog
