Built-in ND filter at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > Canon Optura Junior Watchdog
High-end affordable consumer 1-CCD camcorders. PAL users invited!
Old July 20th, 2005, 09:22 AM   #1
Built-in ND filter
I have a wide-angle lens that I'll be using with the Optura 60. Can I use the built-in ND filter with this lens, or do I need to purchase an ND that fits in front of the wide-angle?
I'm trying to figure out what effect the order of filters/lenses has, if any.
Jason J. Gullickson
Producer
the second society
http://2soc.net
Jason J. Gullickson is offline
Old July 20th, 2005, 12:37 PM   #2
Images: 32
The internal ND filter will work with any wide angle lens. You can use it at the same time with an external filter for more control of the light.
Re: filter/lens order
Stacking external filters increases your chances of having image problems. You may experience issues with vignetting, flaring, or zoom thru, depending on your setup. You'll have to experiment to see what works best.
It's usually better to mount filters on the outside of your wide angle lens, though I've had good success sandwiching filters - one at a time - between the WA lens and camcorder.
Michael Wisniewski is offline
Old July 20th, 2005, 02:06 PM   #3
Excellent, thanks again Michael.
Jason J. Gullickson
Producer
the second society
http://2soc.net
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > Canon Optura Junior Watchdog
