Insanity Check at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > Canon Optura Junior Watchdog
High-end affordable consumer 1-CCD camcorders. PAL users invited!
Old August 9th, 2004, 09:02 PM   #1
Insanity Check
Check this out
Am I correct? Or am I imagining things? Can someone check this with their Optura 10/20 camcorder?
-KiN
Kin Kwan
Kin Kwan is offline
Old August 10th, 2004, 05:43 PM   #2
I'm not sure, but I think that you need to be a member of CamcorderInfo.com and logged in to be able to jump to the thread like that. Otherwise it gives you that error. Could be wrong, and I've been wrong before, so.... :D
Kin, I'm gonna try and borrow my friends Optura 20 and see if you're nuts or not! :)
Curtis
Edit 1: Brain moving faster than my fingers. Filled in missing words.
Curtis Rhoads is offline
Old August 10th, 2004, 09:50 PM   #3
Hehe thanks Curtis!
-KiN
Kin Kwan
Kin Kwan is offline
Old August 10th, 2004, 10:43 PM   #4
Images: 32
So you're saying that you're getting better 16:9 using the built-in 16:9 mode vs. cropping it with the card mode mix?
Perhaps they are using a similar 16:9 method like on the newer models?
Michael Wisniewski is offline
Old August 11th, 2004, 01:13 AM   #5
Hey Michael, thanks for replying!
The newer models (Optura Xi, 30, etc) all have native 16:9 CCDs, which means that there's actually more pixels used. (Correct me if I'm wrong)
My aging Optura 20 uses the old 16:9 method which chops off the top and bottom of a 4:3 frame and stretches the center for a widescreen effect. So technically, less pixels are used for 16:9.
-KiN
Kin Kwan
Kin Kwan is offline
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > Canon Optura Junior Watchdog
