Matching Colors at DVinfo.net
Old May 14th, 2007, 12:39 PM   #1
Matching Colors
Hi,
Can someone please tell me what would be the best way to match 3 GL2 colors? I have bought 3 of them and one of the camera's color is a bit pink.
Please help me.
Matthew Amirkhani is offline   Reply With Quote
Old May 14th, 2007, 12:50 PM   #2
How pink are we talking? If it's way off, send the camera to Canon.
Assuming the problem is somewhat minor, here are some things to do/check:
1) Are you white-balancing to the same object on all 3 cams?
2) If so, maybe shift the color phase a tad toward the green on the cam with the pinkish color.
3) If the problem persists, just fix it with color correction in post.
-->jarrod whaley.
www.oakstreetfilms.com
Jarrod Whaley is offline   Reply With Quote
Old May 15th, 2007, 06:18 AM   #3
Assuming it is not just a white balance issue, can you correct it using Custom Preset -> Color Phase?
dpalomaki@dspalomaki.com
Old May 15th, 2007, 09:07 PM   #4
If you have FCP I would use the scopes in the Capture window. With your reference camera's FW signal, bring up the vectorscope and waveform monitor, take a screen grab, and A/B that with the FW signal from each of the other two cameras (manipulating the in-camera settings, to the extent that you can) until they sorta match. Just one quasi-scientific way to do it, if you don't want to trust your eyeballs. Just remember to save those in-camera settings.
youtube.com/benhillmedia
linkedin.com/in/benhillmedia
Benjamin Hill is offline   Reply With Quote
Old May 15th, 2007, 11:26 PM   #5
Old Boot
Post capture, this is almost the exact same method employed in SONY Vegas too.
"Proving" a draft-finished video - audio, sequencing and CC - is one of the jobs I have to do. But getting it kinda on the button to start with ain't a bad idea! Less work!
Graham Bernard is offline   Reply
