Disabling GL2 Autoshut Off at DVinfo.net
Old April 6th, 2007, 11:36 PM   #1
Does anyone know if you can use a GL2 without a tape in it like you can with the XL2 by turning off the auto shut off feature. I have always recorded with a tape in it as back up. We are planning to feed three cameras through a video mixer to a single DVR to record a live event Thanks for any advice. I have not used my GL2 that much to know this.
Jeff Milligan is offline   Reply With Quote
Old April 7th, 2007, 12:38 AM   #2
You certainly can, we do it every single day.
Chris Harris is offline   Reply With Quote
Old April 7th, 2007, 08:47 AM   #3
Disabling GL2 Autoshut Off (2)
Is turning off the powersave feature the correct way to do this?
Old April 7th, 2007, 09:28 AM   #4
I believe so. I'm away from the GL2's for a couple of weeks, so I can't check, but that should do it.
