Maintaining Manual Focus on GL2 at DVinfo.net
Old October 26th, 2006, 10:58 PM   #1
Ok, this may be a stupid question but can someone recommend a technique for maintaining manual focus on a moving subject while the camera is on a handheld steadycam? I only have 3 people on my crew. Me operating the camera, my buddy holding the boom mic and my other friend holding the reflector.
Michael Pennington is offline   Reply With Quote
Old October 26th, 2006, 11:06 PM   #2
Old Boot
This sounds like a recipe for disaster? However this Canon is real quick with AF, y'know? MF+Steady? Hmmmm... I DO have a LANC Frotti on my DVRig Pro which I do use to keep things in focus by employing the the PUSH Focus technique. I'm wondering if using a LANC somewhere ON the Steady you could do a PUSH AF and back to MF? Yeah, I can see that happening.
Old October 26th, 2006, 11:13 PM   #3
Using the Manual Focus is the only way i can control DOF. Unless there is a better way to get DOF with autofocus.
Old October 27th, 2006, 12:11 AM   #4
Old Boot
Ah! I see! DoF. Hmmm... I have also done this with my LANC. I can use the ZOOM toggle AS a Focus adjust. Back and forth - yeah? Not QUICK quick, but it does do it. I guess what you are after is a simple sensible way to use a kinda whip or rack? Yeah? Interesting with a the Steady. Have I seen Racks and stuff on steadys?
Old October 27th, 2006, 01:06 AM   #5
Old Boot
Some interesting comments for you here:
http://www.dvinfo.net/conf/showthrea...ht=steady+rack
Graham Bernard is offline   Reply
