GL2 External Mic issues - Page 2 at DVinfo.net
Old September 11th, 2006, 05:56 PM   #16
Behave like a GL1
To add to Fred's response, the GL2 should also behave like a GL1 if you have the audio set to automatic rather than manual. Fred's response was with regard to the manual setting. The selection is made with the slider switch on the left side and towards the rear of the GL2.
Mike Donley
Mike Donley is offline   Reply
