Macro Lens for GL2? at DVinfo.net
Old May 11th, 2006, 07:31 PM   #1
Macro Lens for GL2?
Hi,
I have searched the forum and found a few links here and there, but no clear answer to my question. Please advise! I need to shoot a very close up shot of the inside of a sewing machine...we're talking REALLY close. I was wondering if there is any sort of inexpensive close-up attachment or macro lens that will fit on the GL2...do diopters really get that close? Any help or knowledge would be fantastic...thanks, guys.
Erin Hillert is offline   Reply With Quote
Old May 16th, 2006, 11:46 AM   #2
Diopters Work!
Erin,
Yes a diopter does work - very well. I have two close up lenses, both of which I bought to use with my Canon 814 Super 8 camera for stop motion animation purposes. They both have 58mm threads, and I have used them quite a few times with my XM2 with fantastic results.
I have a diopter with a value of +2 which has a range of about 20-30cm this is perfect for detail, and has absolutely no vignetteing but i cannot utilise the whole zoom range (blurs at around 10x). I also use a 'very tight' close up lens which vignettes on the wide end but I can push it to the the full 20x zoom range on the XM2. At full zoom I do have to get very, very close to the object and the image darkens substantially.
I picked both up at a second hand camera house.
All the best,
Janssen Herr
www.janssen.herr.com
www.globala.1go.dk
Janssen Herr is offline   Reply With Quote
Old May 16th, 2006, 03:49 PM   #3
http://www.bhphotovideo.com/bnh/cont....x=7&image.y=7
they've added to the line-up since i bought mine (the cheapie), the GL2 only resolves up to +2, in my experience. not sure if that is enough for you, but it's not bad.....
Old May 16th, 2006, 04:26 PM   #4
The close-up adapters work well. I've used a +1 and +2 Hoya set with the GL1. For higher quality glass, if you need it, check the Canon 250D-58 or 500D-58
dpalomaki@dspalomaki.com
Don Palomaki is offline   Reply
