Firewire 6 pin or 4 pin ?
I need some assisatance in determining whether it is okay to use 6 pin Firewire connection with my GL-2. With 6 pin firewire, the power is supplied to the camcorder and in a 4 pin firewire power is not supplied.
If I use the 6 pin Fire wire connection will the power from my desktop be sufficient in powering the GL-2 or will I have to use an ac adapter (dc coupler) also. From what I understand, if using 4 pin firewire, the dc coupler/ ac power adapter must be utilized for camcorder power I'm at loss regarding 6 pin firewire, power requirements, etc. Thanks for any input |
#2 | |||
Old Boot
Grazie |
4 pin Firewire
Here is an excerpt from Wikpidia regarding no power to 4 pin firewire
"The Sony-branded i.Link usually omits the power part of the cable/connector system and uses a 4-pin connector. Power is provided by a separate power adaptor."
John |
Fred Retread
PC's usually have a 6-pin socket because they're willing to supply power if the connected device wants it. The GL2 doesn't want any power from the other device so it has a 4-pin socket. It won't accept a 6-pin plug. So the answer, as Grazie said, is a 6-pin to 4-pin cable. Physically it fits the PC socket, but the two extra connections aren't used.
"Nothing in the world can take the place of persistence..." - Calvin Coolidge "My brain is wired to want to know how other things are wired." - Me |
#5 |
Firewire connections
Okay, I understand now, Thanks.
John |
