GL / XM assorted posts, 2003 - Page 2 at DVinfo.net
Old January 5th, 2003, 07:23 AM   #16
Re: Fishing with LANCS
" The second question is that in 5 minutes or so the camera turns itself off. Is there a way to overide this function or is there some other way that I haven't figured out yet to use my remote to turn the camers on and start filming?"
From the manual, page 36:
"The camcorder automatically turns off if you leave it in record pause mode for more than 5 minutes to protect tape and video heads. You can select whether to turn off the camcorder (SHUT OFF) or only the recorder section (VCR STOP).
At VCR STOP, the camcorder remains turned on, so that the camcorder settings such as aperture and shutter speed are retained. Press the start/stop button to start recording from the VCR STOP state."
The real problem with recording your fishing is that you will no longer be able to exagerate 'the one that got away'.
Good Luck!
Samuel
Samuel Berning is offline   Reply With Quote
Old January 5th, 2003, 11:32 AM   #17
Old Boot
Oh yes you can! What about morphong software - hee hee! ;-)
Old January 8th, 2003, 02:34 AM   #18
Can I Deal with "warmth" in post?
Just received my GL-2 a week ago. Got a good deal from a reliable seller with a US warantee. I started reading DVi Communityand found it incredibly informative. Followed threads that had great questions that not only helped me learn more about my camera but also made me wonder if my camera was malfunctioning and I didn't know it yet. So I played with it, tested it and just tried the color warming tests, everthing works fine. I was impressed with the picture quality straight out of the box but after switching to movie mode and reducing the sharpness and bumping up the gain and setup, I'm thrilled!
My question to anyone who knows is, "Can't I just white balance with pure white and deal with warmth and/or coolness of color in post using Premiere or After Effects or some other post software or am I missing something in the capture by not warm balancing my picture from the get-go with 5 or 10% Cyan or Blue for that nice warm look that I like?"
Ed
Ed Anders is offline   Reply With Quote
Old January 8th, 2003, 06:42 AM   #19
Warden
You could but it would lower the quality of your footage slightly. Everytime you render a project the files are altered as part of the rendering process. This slight alteration lowers the quality of the DV material. The best quality will result from doing the WB in camera.
Jeff
Old January 8th, 2003, 07:29 AM   #20
slas_swe
Posts: n/a
XM2 full frames
Hi!
I'm thinking of buying a XM2. Are there any full frame capture pictures available somewhere?
I remember a problem with the xl-1(s) with a couple of black lines at the bottom. Are there any of these problems on the GL-/XM2?
/Slas
Old January 8th, 2003, 10:10 AM   #21
I've got several movies and still posted on my .mac website...here's one of the links...the rest are available once you get to the page.
http://homepage.mac.com/barrygoyette/PhotoAlbum8.html
buddy1065 has also posted and extensive array of clips and stills...do a search for his posts to find his site.
Regarding the black lines along the edge of the frame...with the gl2, canon has solved this issue..no blanking in the frame.
Barry
Barry Goyette is offline   Reply With Quote
Old January 8th, 2003, 04:51 PM   #22
RED Code Chef
Jeff is right. But I have two things to add to that:
1. Output medium
If your output is NOT DV than you will not have the above slight
quality loss if you do it right (ie, transfer the footage from your
editing application into your color correction suite (if you don't
use the same application) in either a lossless compression or
no compression at all) and output to a format that would require
a re-encode anyways (MPEG1, 2, 4 or Web etc.).
2. WB vs. post
I would definitely try to get the best picture on set without putting
extraordinary amount of time in it (how much is acceptable is up
to you and the time available to shoot everything). Then you will
have less or nothing to do in post. BUT, I personally will fiddle with
the shots in post anyway because I want to add black bars to
create the letterboxed widescreen version. And I almost always
tinker with colors and contrast etc. anyway to get in my taste
a better picture. How much you want to do this is up to you. I
suggest you try some testing (especially with the software
because this will break or make it!!!) before you go ahead with
anything serious! By default Premiere doesn't have much to work
with. After Effects (production bundle especially) has some nice
tools. Avid includes them I think as does Final Cut Pro. There
are ofcourse dedicated post applications out there for compositing,
effects and color grading work.
Good luck!
Rob Lohman, visuar@iname.com
Old January 8th, 2003, 05:24 PM   #23
Thanks Jeff and Rob,
that makes complete sense. I will always white balance but not necessarily to the light blue cards. I am comfortable transfering and altering uncompresses data knowing what I know now. I guess in-camera warming to 10% Cyan would make for better looking daily's, especially when the suits and bean-counters insist on watching them and injecting their 2 cents, but for my own projects I have enough imagination to see the potential for post production tweaking. Thanks again!
Old January 9th, 2003, 01:40 AM   #24
Leaving Mic Att. on all the time?
Hi,
According an article on the website of dv.com it's best to leave the mic att. constantely on to reduce noise. The audio level should be set manually to optain the best audio.
Are there people here who do this?
What are your thoughts?
The article can be read on:
http://www.dv.com/features/
article:DV Camera Audio: Real Numbers, Real Recommendations
Dirk
Dirk Goris is offline   Reply With Quote
Old January 9th, 2003, 05:28 AM   #25
The input preamps on many MiniDV camersa hae a relatively high noise floor. Using MIC ATT ON and reduces gain, so the nosie floor of the recorded sound is correspondingly lower, but so is the desired sound level. MIC ATT setting provides a benefit only if the audio input (to the mic or mic jack) is high enough. This is often the case with powered mics such as the ME66 and wireles systems, and may be the case in many venues such as concerts.
If the recorded level is too low, you may be able to add a noise gate, gain and/or compression in post.
Some camcorders have higher nosie floor when in manual volume control method, this was the case with the VX2000 and PD150 when they were released. The PD150 was fixed by Sony, not sure about later production of the the VX200.
The GL1 did not offer any manual gain control.
In summary, whether or not it is good for you epends on what and how you shoot and edit. Try it, expirement and see.
Old January 9th, 2003, 05:18 PM   #26
GL2 Resale Value
If i were to purchase a GL2, from a board sponser of course!,
and use it for say 3-4 months on a film project what could i expect for a resale value?
Other than keeping it in perfect condition, what factors would lead to a quick & resonable sale. (extended warranty etc)
The only place in madison to rent a camera has 1 xl1 and it is $175 a day. So i guess buying(credit union loan) -> shooting film
-> reselling (paying of loan) is my only option for now.
Jed Williamson is offline   Reply With Quote
Old January 9th, 2003, 07:23 PM   #27
Finally got my GL2
I finally broke down and bought my GL2. So far so good but this thing is definitely not point and shoot. The manual controls are sweet but it's going to take me longer than anticipated to get the hang of them. The 20x optical zoom, which is why I chose it over the Sony, is much better than expected.
I've decided to try to make or at least be creative about some of the accessories though. For a bag, I came across a really neat "cooler" type bag with a ton of padding at Sears. I think I could customize it to work just fine for my camera and save about $75 to boot.
I was going to get a polar mitten, but at $149, I think I'll try to invent something. My wife thinks she can sew up some fleece stuff and make it work. It's worth a try at least I think. It's *freezing* here so I think it would be prudent.
The mic seems to be just fine for now although I do plan on getting a shotgun. But... I'd like to try to make a smallish windsock thing for the built in mic. Any suggestions on materials for that? The Canon one sells for $119 or something and frankly, that is just insane.
Rich Stone is offline   Reply With Quote
Old January 9th, 2003, 08:03 PM   #28
Good choice!
Congrats, I got mine 2 weeks ago and I love it. I picked up a lunch-box type bag from Home Depot for $19.95 (Canadian) and it works great! It is thermally insulated (for keeping food hot or cold) and has two padded compartments, one for my GL-2 and the other for all my assecories and lenses. Comes with a short handle and a clip on shoulder strap. If you were to find this design in the camera accessory section of any store it would probably go for $100 -$200, but since it's only a lunchbox for construction workers it's $19.95!
Enjoy your purchase,
Ed
Old January 9th, 2003, 08:08 PM   #29
Exactly Ed. I saw another bag in a sporting goods store for $30 or so that would do nicely as well. There is just something about spending an extra $100 for something because it says "camera bag" on it instead of "lunchbox" or whatever that drives me crazy.
Old January 9th, 2003, 08:13 PM   #30
Jed,
I bought my GL-2 new for $1895.00 so for a little more than 10 days of rental you could own one of these babies. I got mine on Ebay and I don't recall seeing many used models for sale but if you do a search try typing in GL2 as one search type and GL-2 as another. I found that I got different results for each. I'm guessing a used model would go for at least half the new price.
Good luck,
Ed
