What is up ? at DVinfo.net
Old December 6th, 2005, 10:06 AM   #1
What is up ?
I just bought a Sony DSR-11 and it is having trouble playing my GL2 tapes. I used my second camera which is a canon and had no problems. I also recorded back to the deck from the computer and there was no problem. I used the same tape (panasonic) and they all work except from the GL2. The play back gas gliches in video and audio.
John Arman is offline   Reply With Quote
Old December 6th, 2005, 10:15 AM   #2
I had same problems with my DSR40 deck. It seems like heads on GL2 are missaligned. Usual cleaning/head adjustment at Canon service should sort this out.
XM2
Sony DXC637P BetaSP
Darko Flajpan is offline   Reply With Quote
Old December 6th, 2005, 01:10 PM   #3
Before sending your camera for alignment you should capture and/or copy any tapes which you made with it by connecting to another camera/deck/computer via firewire. If the heads are not aligned then you may find that the camera itself will no longer read its own tapes after repair - just like your DSR-11.
Old December 14th, 2005, 03:53 PM   #4
Are you recording in SP or LP mode? I know that my DSR-20 wont play LP at all.
Tustin Larson
Tustin Larson is offline   Reply
