white balance gl1 question at DVinfo.net
Old November 16th, 2005, 06:58 PM   #1
I'm trying to figure out how to set manual white balance and i dont understand why i cant. i know i can find this in an online manual but i dont have the ability to run a pdf reader on this pc as i am at work. This answer would be greatly appreciated.
video : xl2 / letus35xl / bogen 503
photo- canon 1dmkII - bronica etrsi
Andrew Todd is offline   Reply With Quote
Old November 16th, 2005, 07:02 PM   #2
Run camera on manual settings. Zoom in and focus on a white card. Hold in the button below the flip out screen that looks like 2 triangles pointing one another. It will blink on your monitor. Once it stops blinking you are balanced.
James out------
Check out the Southern Winds Film Festival. Call for entries is now open!
http://www.southernwindsfilmfestival.com
http://www.phigmentphilms.com
James Bridges is offline   Reply With Quote
Old November 16th, 2005, 07:06 PM   #3
mine might be broke... thats what ive been trying. It doesnt ever seem to stop flashing
Old November 16th, 2005, 07:32 PM   #4
It will keep flashing sometimes if your light is too low. I have also had that problem if you are too close to the white card for some odd reason. Try backing up a bit and throwing a touch more light to it. If that doesn't work, do the un thinkable and back your zoom out all the way and try it. Turn away from the white card and see what happens. Your balance may be damaged on the camera itself. You may have to judge it by eye then color correct in post. What happens?
James out------
Old November 19th, 2005, 06:12 AM   #5
It says on the manual it can do this with the slow flashing but this will improve the setting and not to worry about it, whats your footage like, this would be the decider.
Paul
Paul Gallagher is offline   Reply With Quote
Old November 19th, 2005, 09:39 AM   #6
Old Boot
Paul . .oh yes.
However, is the ANY environment that works for you - with WB-ing?
Grazie
Old November 19th, 2005, 09:46 AM   #7
If you mean the slow flashing, its only in a badly lit indoor enviroment, never during the day, only under bad artifical lighting, I've not owned mine that long.
I usually use a XL1s and it never has this /problem/setting so to speak.
Sorry I can't be of more help.
Is the footage ok that you got?
Paul
Old November 20th, 2005, 04:43 PM   #8
ive got it working now. It just seems harder to balance on colors other than white. Filmed a band play last nite at a party. Low lights and lots of smoke from the smoke machine with people skating a halfpipe right beside it. Made for some good footage. Some grain because of the lack of lights but i liked the orangey effext that a light blue white balance gave me especially with the smoke. I would have been happier if my friend would have thought to bring his vx1k to catch all the skate tricks to cut with..oh well ..next time
Old November 21st, 2005, 05:20 AM   #9
Old Boot
" It just seems harder to balance on colors other than white. " Now I don't understand what you are doing?
Please explain .. . Grazie
Old November 21st, 2005, 03:32 PM   #10
i mean when balancing on "off-whites"
Old November 21st, 2005, 03:40 PM   #11
Always balance on white. Even if you just carry a white sheet of paper with you in your back pocket. This is the only way to get a true white balance.
James out------
Old November 22nd, 2005, 05:23 PM   #12
if i was trying to get a "true" white balance i would have used white. i like the look of a very light blue
Old November 22nd, 2005, 07:48 PM   #13
Cool man, just trying to help out. Good Luck.
James out------
Old November 23rd, 2005, 03:57 PM   #14
appreciate the help. Thank you
