WD-58H, WC-DC58 or Sony VCL-HG0758 at DVinfo.net
Old December 12th, 2002, 11:24 AM   #1
Hi, looking for a wide angle converter.
I know canon recommend the the WD-58H, the WC-DC58 has also 58mm but it mostly been used with the the Canon Powershot G1/2, but are this converter (WC-DC58 or Sony VCL-HG0758) will be fine, too for the GL2??
And how about the quality, and are there other converters you can recommend me??
Chungle
Chung Lee is offline   Reply With Quote
Old December 12th, 2002, 01:19 PM   #2
Old Boot
Chunglee - I use the Canon WD-58H. It works for me. Nice wide shoots. No obvious distortion at edges. Where I bought it was having a special offer oin it got at 33% off the original price. Had to buy it!
Grazie
Old December 12th, 2002, 02:27 PM   #3
Hi Grazie Bernard !
Thanx for the info.
Are you from Europe?? I would like to know if its possible to get the 33% in the internet in europe, cause I live in germany.
The cheapes I would get will be 219€
Old December 13th, 2002, 06:13 AM   #4
hey chunglee: i also want to buy the wd-58h here in germany, but canon has not produced enough of them - there aren't enough out there, so it may take some time to get it. just thought you should know that.
Mark
Mark Härtl is offline   Reply With Quote
Old December 13th, 2002, 06:48 AM   #5
Old Boot
Chunglee - There is a shop in central London - Tottenham Court Road called "ASK" that are doing the 58 Canon WD for £150.00GBp - I don't know how that compares with what you have been told? Their tel number is ++44 20 7323 2747 - www.askdirect.co.uk
I hope that helps
Grazie
Graham Bernard is offline   Reply
