Wide Angle Lens Converter for GL / XM - Page 2 at DVinfo.net
Old July 22nd, 2002, 05:36 PM   #16
The Century 0.65x does NOT have filter threads. In any case a filter is likely to vignette at widest settings.
Old August 7th, 2002, 11:55 AM   #17
crystal optics .5x and nle
I only just discovered that I can see the corners of my 82mm uv filter when zoomed out and using my .5x wide angle (which i just keep on my camera) but it only shows up on my mac. it isn't anywhere near 'tv safe area' but i assume it will show up on qt movies and the like.
i'm sure crystal optics are the wal-mart of the lens world, but the quality is good and the vignetting is minimal, besides i like the vignetting- and for 150$ it sure beats standing across the room to get a medium shot of a person.
and they have threads!
check ebay or any camera shop in chinatown for crystal optics gear.
Jason Bagby is offline   Reply With Quote
Old August 8th, 2002, 04:21 AM   #18
Woodyfang
wide angle adaptor - price
As a DV newbie I am budgeting for my upcoming purchase of XM-2 and whatever else I can afford with it, hopefully the Wide Angle Adaptor, a Steadicam JR, and some filters. Does anyone know the price of the Wide Angle adaptor in the UK/US
Also, I'm hoping to make music videos for which I will need some really screwed up filters. does anyone have any reccomendations for rare/extremely weird FX filters?
I read on a separate thread about people makin their own which also interests me. Would one buy the empty threaded ring and then fit coloured translucent/transparent materials into the ring, experimenting with what works
cheers
10 films online http://www.undeadarmy.org
STOP PRESS!! http://www.honeyweasel.com STOP PRESS!!
Lighting Cameraman / Director / Producer / Music Producer / DJ / Web Designer / Visualist / Media Student / IT Tutor / Digital Artist
W00dy See, W00dy d00...
Hagop Matossian is offline   Reply With Quote
Old August 8th, 2002, 06:09 AM   #19
In the US, the benchmark wideangle adapter is the Canon WD58 which gives a 0.7x factor. Street price in the USA is on the order of US$170. There are some cheaper adapters that are also of lower quality, and some substantially more expensive models as well (e.g., Century Optics). And you can find a range of multipliers as well; e.g., 0.55, 0.65, 0.7, and so on.
Old August 8th, 2002, 08:29 AM   #20
My Century .55 was $226 US.
b
Blake Haber is offline   Reply With Quote
Old August 8th, 2002, 12:03 PM   #21
new wide angle lens shade
Where can one order the new lens shade for the WD - 58 , Canon?
Craig Peer is offline   Reply With Quote
Old August 8th, 2002, 02:24 PM   #22
You can order the lens hood by itself, or the WD-58 with or without the lens hood, from our DV Info Net sponsors who are authorized Canon dealers... Pro-Tape, ZGC and Zotz Digital. See www.dvinfo.net/sponsors for contact info. Hope this helps,
Old August 8th, 2002, 03:18 PM   #23
Note that a potentially significant factor with wide angle adapters/converters is whether or not they are full zoom thorugh. Some only allow limited zooming, which does reduce cost significantly.
Old August 8th, 2002, 04:18 PM   #24
lens shade
Thanks Chris. I thought about Zotz ( where I bought my new GL2 2 1/2 weeks ago before taking it to the High Sierra for a " shakedown cruise ") and they said the lens shade is $ 34.00 by itself and not yet in stock ( but coming soon ).
Old August 8th, 2002, 05:43 PM   #25
Woodyfang
thanks guys. Better not quit my job too soon then! stuff in the uk usually costs is £'s what it costs in $'s in the states, so it looks like I'm looking at at least £170 for the Wide angle adaptor. A shame, as I could really do with a new skateboard...
Old August 13th, 2002, 02:50 AM   #26
Most front-end add-on lenses,
WA, telextender, etc., don't have threads for mounting filters or hoods. But, you can find a slightly larger filter that is just wide enough to snap over the outer rim of the extra lens. It can be held in place by a wrap of black gaffer's tape (my cheapo version of this is hose-bandage tape from an auto rack at most grocery stores). Using larger filters, the glass goes out beyond the rim of the shell and doesn't cause as much, if any, vignetting, as one that screws onto threads inside the shell. It may be necessary to put a few wraps of tape around the rim of the add-on, inside where the filter ring goes, to fill out the diameter and make it fit more snugly. Sometimes, I do this same thing to put a hood onto an add-on. I may pull the rubber of the hood off its solid ring and tape just the soft part over the shell.
Large and long-established film camera stores often have boxes full of an odd assortment of filters and hoods, that they like to sell cheaply, just to get rid of them.
Steve McDonald
Steve McDonald is offline   Reply With Quote
Old August 13th, 2002, 03:13 AM   #27
Speaking of 58mm WA lenses, 14 years ago, I paid $160. for an extraordinary WA add-on. It is a .5X and carries the Telesor brand, and is marked as made in Japan. It has flawless quality, with no distortion at any point in the image and no vignetting in any light level or even when backed all the way off on the zoom. I've been using it with step-rings on smaller lenses all these years and if I grab a GL2, I'll have another use for it. I've tried to identify the manufacturer of this solidly-built lens, without success. I suspect the "Telesor" name is just one of numerous marketing brands, that have no obvious connection to its maker. Maybe one of you has run across this brand or knows someone who sells them currently?? I'd recommend one highly, if it could be located. I'd get very combative, if someone tried to deprive me of this one.
Steve McDonald
Old August 13th, 2002, 05:53 AM   #28
Steve, in Texas we'd say that we'd have to wrassle for it.
A quick check of the Google search engine reveals an interesting link at http://people.smu.edu/rmonagha/third/mfg.html which in turn indicates that the Telesor name comes from Masel Supply Inc., a company which I suspect may be out of business now.
Old August 15th, 2002, 07:12 PM   #29
Hood later?
Am I correct in assuming you can get the Wide Angle hood for the WD58 afterwards?
Joshua Wachs is offline   Reply With Quote
Old August 15th, 2002, 08:09 PM   #30
You're asking if the hood can be purchased separately, and the answer is yes, it can. Hope this helps,
Chris Hurd is offline   Reply
