Wide Angle Lens Converter for GL / XM - Page 16 at DVinfo.net
Old October 7th, 2003, 09:44 PM   #226
Should I get a GL 2 Wide Angle Converter?
Hi guys, I'm new to the boards here.
So, I have a GL 2, that I use occasionally. Quite often, I guess. So, is it worth getting the wide angle lense?
Does it distort the picture?
Is it good for a little under $200 from BandH Photo?
http://www.fischware.org/cineview
Adam Sayovitz is offline   Reply With Quote
Old October 7th, 2003, 10:21 PM   #227
Mine never left my camera since I received it !
http://www.natzo.com/GL2-WD58H.jpg
Yes there is some distortion but the subject (fridge) was pretty close in that case.
It has never been a problem so far and you can zoom all the way through.
Dany
PS: If you do a quick search on this topic you'll find a lot of feedback from people wondering about this WA.
Dany Nativel is offline   Reply With Quote
Old October 8th, 2003, 08:53 AM   #228
I too keep the wide angle on most of the time. Works well for me.
Sandy
Alexander McLeod is offline   Reply With Quote
Old October 8th, 2003, 10:36 AM   #229
Retired DV Info Net Almunus
Indeed, any truly wide-angle lens will present some distortion under certain circumstances. Subjects, such as faces, up-close can take on a cartoonish appearance. Vertical lines at the edges of the frame, when the lens is at its widest setting, may get some barrel distortion.
But the WD-58 is an excellent add-on lens and greatly expands the versatility of the GL2 (and GL1). It's a real bargain and should be in your tool box if you use the camera in a variety of situations.
The only downside is filters. Be aware that the WD-58 cannot accept any screw-on filters in front. If you want to use filters with it you'll have to get a rrod-mounted matte box and use square filters.
Old October 8th, 2003, 06:47 PM   #230
Another question, are there any other lens attachments available for the Gl 2? (And I mean other than filters)
Old October 8th, 2003, 07:26 PM   #231
Do you mean accessory lenses such as those from Century Optics?
Old October 9th, 2003, 05:42 AM   #232
Would it be possible to attach a screw-on filter to the GL2 lense, then screw the W/A adapter to the filter?
Corey Sturmer
Producer - Woffester Productions
Corey Sturmer is offline   Reply With Quote
Old October 9th, 2003, 06:17 AM   #233
Very possible. My friend has UV and Polarizer filters topped off with the Canon WD-58 and has had no signs of vignetting.
Ryan Krga is offline   Reply With Quote
Old October 9th, 2003, 10:37 AM   #234
Possible, yes. But at some cost to imaging and focus. The WE-58 is designed to be at a very specific position in the sequence of optical elements that compose your lens assembly. Pushing it out by the depth of a filter or two will have some impact on the image.
Besides, why in the world would you put a UV filter between the 58 and the main lens?!
Old October 9th, 2003, 11:34 AM   #235
lazy
that is why sometimes I have my UV filter betwen my main lens and the WD-58. It is just the ease of not to screw it off, then screw it on after I finished with the wide angel when I am somewhere shooting some event.
But you have a good point.. in the future I will try to remove the UV filter first :)
Joris Beverloo is offline   Reply With Quote
Old October 12th, 2003, 04:35 PM   #236
Well, the UV bewtween the 2 lenses might be pointless but it's not entirely pointless if it's say a polarizer or colored filter. I've used a polarizer and didn't really notice a huge difference in quality.
The Wide angle though helps alot if you are looking to widen your shot choices.
http://www.veoh.com/channels/filmmaker
My clips and films.
Bob Benkosky is offline   Reply With Quote
Old October 12th, 2003, 11:31 PM   #237
"Besides, why in the world would you put a UV filter between the 58 and the main lens?!"
Ken,
I am new to this but I thought one of the reasons for the UV filter was to protect the Cam! Would that not be a good enough reason to have it between the lense and the WD58??
Or, have I misunderstood something, don't you need the filter if using the WD?
Thanks for your patience.
Alan McC
Alan McCormick is offline   Reply With Quote
Old October 13th, 2003, 12:04 AM   #238
Alan,
UV filters on video cameras are indeed most often used as do-nothing protectors for lenses.
Sandwiching a UV filter between the camera's main lens and a lens attachment such as the WD58 offers no protective value whatsoever.
Old October 13th, 2003, 12:32 AM   #239
if you want filters with your wd-58 or century wide angle..you should look at the century optics sunshade
you'd also have to get square filters
Alan Tran is offline   Reply With Quote
Old October 13th, 2003, 01:14 AM   #240
Thanks Ken, that is what I needed to know.
Alan, a good link, thanks also.
Alan McC
