Custom Settings you use in low light and in bright light? at DVinfo.net
Old November 27th, 2002, 08:23 PM   #1
What custom setting do you use in low light around sundown or indoors with just tungsten light and in bright light, like at 12:00 noon outdoors. Is auto sufficient?
Leonard.
Leonard Leguizamo
Canon GL2 with:
WD-58H (wide angle adpt)
BP930 batteries
Use Fuji DVM60 tapes (SP mode)
Leonard Leguizamo is offline   Reply With Quote
Old November 29th, 2002, 08:15 AM   #2
Auto may be sufficient. If not then these setting are the ones I have found to keep grainy footage out of low light:
Sharpness down a notch
Setup level up a notch or two
Shutter speed to 1/30 may help
Gain at 6 to 12db....18db may show grain
Open exposure setting as needed
Am I missing anything?
Bill Hardy is offline   Reply
