GL1 to laptop without firewire at DVinfo.net
Old June 8th, 2010, 12:55 PM   #1
Is it possible for me to transfer to my laptop using anything other than firewire. My pc is down and I need to upload this video asap. My lappy doesn't have a firewire port. Help! ....and thanks.
Ken Ragas is offline   Reply With Quote
Old June 12th, 2010, 01:32 AM   #2
If your laptop has a PCMCIA slot you could buy a card that has firewire port on it. They're very cheap.
If your laptop has some kind of analog video input, you could use the A/V out on the camera.
Otherwise...no.
Jeremiah Rickert is offline   Reply With Quote
Old June 12th, 2010, 03:41 AM   #3
And if your laptop has an expresscard slot you need to buy a firewire expresscard.
Gabor Heeres is offline   Reply
