Anyone use GL-2 + Final Cut Pro? at DVinfo.net
Old February 6th, 2010, 10:40 PM   #1
Gents!
I'm brand new to this software and am in the process of getting my feet wet.
I want to export the entire contents of the timeline ("print to tape") to mini-dv tape.
What things should I be aware of & watch out for..... in order to be successfull?
I need to know because the computer and software I use will not be mine and my time on it is limited so it would be nice to get it done quickly with a minimum of delay, frustration and surprises.
Do any of you use the GL-2 with Final Cut Pro?
Would love to hear from you and get your pointers/advice.
Bruce Pelley is offline   Reply With Quote
Old February 7th, 2010, 12:56 PM   #2
There should be nothing special about using a GL2 with Final Cut. I've used GL2 footage and imported from the GL2, and it is just like any other camera in that regard.
I have never printed to tape from Final Cut at all, but if you do a quick search on how to do so in Final Cut, it would apply to the GL2 just like any other MiniDV camera.
Greg
Greg Donovan is offline   Reply With Quote
Old February 9th, 2010, 08:18 PM   #3
Confirmed. Nothing special at all.
Worked perfect.
Bruce
