Exposure Scale-Indicator? What's the Value of it? at DVinfo.net
Old June 6th, 2005, 12:37 AM   #1
Old Boot
. .. back again . .
1/- How do you use it? What benefits does it give you?
2/- How is this better/worse than zebra bars? Exposure gives a general value to ALL the frame - ZBs give you area-specific representations, yes I know, soooo... how do you use this Scale?
TIA,
Grazie
Old June 6th, 2005, 01:00 AM   #2
Well, it looks nice :-), anyway I trust to zebra stripes.
XM2
Sony DXC637P BetaSP
Darko Flajpan is offline   Reply With Quote
Old June 6th, 2005, 09:44 AM   #3
Retired DV Info Net Almunus
The exposure index in the viewfinder --the line with the floating triangular indicator-- can be very useful. In brief, it's the camera's back-seat driver. The position of the triangle indicates the camera's current exposure values as compared with the exposure that it would normally set under a programmatic mode (Tv, Av, P, green box). So if you know you wanted to, say, manually underexpose a scene by a stop (compared to the camera's default exposure) you can continuously see whether or not you're dong that.
Zebra bars only show areas of the image that have reached or exceeded the zebra's luminance settings. That is, zebras only warn of blow-outs. That's a very different indication than that of the exposure index.
Old June 7th, 2005, 07:32 AM   #4
Gee whiz, Ken. You're so much better than the operator's manual!
Old June 7th, 2005, 09:38 AM   #5
Old Boot
Oh yes Chris, Ken is - and he's ours! However, he DOES need the right question too y'know!
KEN ! THANK YOU! ! ! !
Grazie
Old June 7th, 2005, 09:44 AM   #6
Images: 1
Works the same way on the bigger XL series cameras also. Good explanation, Ken. I have always understood the difference but I had never been able to state it so eloquently!
-gb-
Greg Boston is offline   Reply
