Microphone setting to Voice at DVinfo.net
Old May 4th, 2005, 07:56 PM   #1
When you are recording conversation on the GL-2, do you change the microphone setting to VOICE?
does it make a difference from the NORMAL setting.
also, on windy places when recording, does W. Screen make a noticeable difference?
Joe Mobic is offline   Reply With Quote
Old May 4th, 2005, 09:40 PM   #2
Retired DV Info Net Almunus
Joe,
The best answer is for you to try these settings for yourself. The "voice" setting seems to slightly shift the frequency sensitivity to heighten the range of voice frequencies. Similarly, the "windscreen" setting filters a bit of the low-frequency wind rumble out. In my experience neither is very effective. For windy conditions nothing works better than to use a good physical windscreen, such as a blimp or furry screen, on a mic.
Old May 5th, 2005, 06:20 AM   #3
Old Boot
Ken? Put an " i " in the italic-code . ..
G
Old May 5th, 2005, 06:45 AM   #4
do the settings really matter?
i've so far only placed the setting on normal, but recently read the manual and found out these new settings.....
manual reading does help, but was wondering if anyone has noticed a profound effect by changing these settings
