25% drop in res?
I was told that the GL2 resolution drops by 25% when you go into frame mode. Is this true?
Thanks for your help everyone. |
This has frequently been discussed in the past, mostly in relation to the XL-1, but I think you'll find the issues are the same:
http://www.dvinfo.net/conf/showthrea...threadid=14726 http://www.dvinfo.net/conf/showthrea...threadid=35158 http://www.dvinfo.net/conf/showthrea...=&threadid=983 http://www.dvinfo.net/conf/showthrea...&threadid=2956 Use our seach feature to help find answers to questions like this. |
There doesn't seem to be a lot of solid information in any of that lot, though.
I've set my XM2 up on a tripod in front of a resolution chart and used the remote to switch between normal and frame modes, and it does indeed seem as though there's a resolution loss of 25% - I eyeball about 440 lines of vertical res in normal mode versus about 330 lines in frame mode. What's missing is the explanation why. There's some reference to "interpolation" and "blending", but I don't think it's based on any solid technical information. It's an academic point, of course, because there probably isn't anything that can be done about it, but some of us just like to know these things. |
RED Code Chef
The reason this happens is that the GL1/2 and XL1(S) line of
camera's does not have a true progressive mode. This frame mode uses a special algorithm and CCD accessing to achieve the progressive look. It is better (in my opinion) than a lot of de-interlacing programs/algorithms, but you indeed loose some resolution. Personally I don't care about this. It's the story and entertaining value of my movie that should hold viewers. Not the amount of lines of resolution it has. As I always say: if it looks good enough it to your eyes....
Rob Lohman, visuar@iname.com DV Info Wrangler & RED Code Chef Join the DV Challenge | Lady X Search DVinfo.net for quick answers | Buy from the best: DVinfo.net sponsors |
#5 |
Fred Retread
Seems odd, then, that the GL2 manual (p. 50) says,
"The frame mode can be used when you wish to look at a video scene by scene, free from field slippage........The vertical resolution of the image is improved by 1.5x. During playback pause the video at any time if you would like to see a crystal clear still image in the display or on a connected TV screen....."
"Nothing in the world can take the place of persistence..." - Calvin Coolidge "My brain is wired to want to know how other things are wired." - Me |
#6 |
No, that's right. A "still" in normal movie mode is a single field, which has only 50% of the resolution of a full frame. A still in frame movie mode is the full frame, which has 75% of the resolution of a normal movie mode frame. 75% is 150% of 50%.
It's still not clear to me why, though. CCDs are always progressive. Usually, lines of video are constructed by averaging two successive rows of data from the CCD - for the upper field, the first and second rows are averaged to create the first line, the third and fourth rows are averaged to create the second line and so on. For the lower field, the second and third rows are averaged to create the first line, the fourth and fifth rows are averaged to create the second line, etc. This reduces twitter and improves the signal to noise ratio by 3dB. Some broadcast cameras allow you to control the ratio of successive rows to trade off noise and flicker against resolution. Because the green CCD in the Canon cameras is offset from the red and blue CCDs by half a pixel ("pixel-shift"), I wonder whether the video lines in normal movie mode might be created by using a 25:75/75:25 split instead of 50:50. This will give a sharper vertical resolution, and re-align the green rows with the red and blue rows, at the expense of increased twitter and noise. For frame movie mode, however, there will already be twice as much noise (because you can only use one read of the CCDs instead of two, so you effectively have half as much signal and the same amount of noise) and if the purpose of frame movie mode is to achieve "crystal clear" stills, then you'd obviously also want to minimise twitter. It seems to me that, since there's no technical limitation that prevents frame movie mode from having the same resolution as normal movie mode, the reduced resolution might be a deliberate choice on the part of Canon's designers, in order to reduce noise and twitter. |
