How do I make it play through to the TV? at DVinfo.net
Old February 4th, 2005, 01:44 AM   #1
When editing I usually have things set up to where I have the Gl2 hooked up through FireWire, use FCP to edit, and have the GL2 connected to the TV via RCA. Sometimes this makes it so that what I edit shows up on TV - this is incredibly helpful. However recently, this has not been happening and I have no idea why. What settings should I enable, what should I do?
Nick P. Robinson is offline   Reply With Quote
Old February 4th, 2005, 05:25 AM   #2
RED Code Chef
You should first look at what has changed. If it worked previously,
it should work now as well.
Camera needs to be in VCR mode and you need to tell FCP it
needs to output over firewire and preview there. I have no idea
how to do this since I'm not on the Mac platform.
Also take a look at this thread:
http://www.dvinfo.net/conf/showthrea...threadid=38744
Rob Lohman, visuar@iname.com
Rob Lohman is offline   Reply
