I am a baby! I just got me a GL2 a quick question? Please help at DVinfo.net
Old January 18th, 2005, 11:42 AM   #1
After reading from all of you Pro People which I thank, I got me a canonGL2
I need help.
I have a VL10video light and i am buying the Sennheiser MKE300 mic,
I want to have both running or attach to the GL2 so that i can record the sounds and at the same time have the light on.
Do i need to buy the canon MA-300 mic adapter or what do i need buy
or can someone give me some tips
Thank you Very Much
Danny from El Paso Texas
Danny Mendoza is offline   Reply With Quote
Old January 18th, 2005, 03:39 PM   #2
The MA-300 includes an accessory shoe at the top so you can mount your VL-10i up there. Just be careful because the entire assembly is plastic and all that stuff will put a lot of stress on the GL2's hot shoe.
Old January 18th, 2005, 04:27 PM   #3
Thanks Chris Hurd
Mr. Hurd
What if instead i buy the Azden pro wireless mic system
Is that a better route to go? without hurting the shoe mount, and if so how will i connect both the
wireless mic and the light, is there a device that can do that and
please where can i buy it from.
Many Thanks
Regards
Danny from el Paso Texas
Old January 20th, 2005, 09:49 AM   #4
Bracket 1 for your wireless receiver
You can use a device such as the Bracket 1 to hold your wireless receiver. I use one on my GL2 and it works well.
http://www.bracket1.com/
You can buy them from B&H.
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=284435&is=REG
<<<-- Originally posted by Danny Mendoza : Mr. Hurd
[...]how will i connect both the wireless mic and the light, is there a device that can do that and please where can i buy it from.
Donovan Kruger is offline   Reply With Quote
Old January 20th, 2005, 11:57 AM   #5
Don't Use Metal
Avoid using a bracket that has a metal mounting plate. The shoe on a GL-2 is a smart shoe for connecting a video light or a microphone. According to Canon tech support, a metal plate placed in a smart shoe might damage the camera. This was not a problem with a GL1 which did not have a smart shoe.
Mike Donley
Mike Donley is offline   Reply
