MA300 XLR microphone adapter - Page 2 at DVinfo.net
Old September 15th, 2002, 08:45 PM   #16
Retired DV Info Net Almunus
Look through this section of the site and you'll find several discussions already running on this subject, Tony.
Old September 15th, 2002, 08:58 PM   #17
Outer Circle
If you paid with your hard earned money for a new GL2, why not get it looked at by Canon. You do have a warranty, do you not?
Old September 21st, 2002, 02:22 PM   #18
MA-300 Audio Channel Question
When you hook the MA-300 to the GL2, does one of the XLR inputs record to the left audio channel and the other XLR record to the right? This would mean that if I was using a wireless lapel into one XLR and a camera mounted shotgun on the other XLR, that when I played my video back I would be hearing the lapel and shotgun on two different sides of the TV (one on the left channel and one on the right). Is this true, or would I be hearing both the lapel and shotgun on both channels? If Canon designed the MA-300 this way it seems pretty darn stupid enless you were using different two mics for stereo recording. Would there be any way to correct this problem? What would I do to get both mics on both channels? Thanks!
Scott Silverman is offline   Reply With Quote
Old September 21st, 2002, 03:34 PM   #19
Howdy from Texas,
<< When you hook the MA-300 to the GL2, does one of the XLR inputs record to the left audio channel and the other XLR record to the right? >>
Yes. This is exactly how it's intended to work.
<< This would mean that if I was using a wireless lapel into one XLR and a camera mounted shotgun on the other XLR, that when I played my video back I would be hearing the lapel and shotgun on two different sides of the TV (one on the left channel and one on the right). >>
Playing back the raw video, before editing, yes, this is what you would hear.
<< Is this true, or would I be hearing both the lapel and shotgun on both channels? >>
No -- one mic on one channel, the other mic on the other channel.
<< If Canon designed the MA-300 this way it seems pretty darn stupid enless you were using different two mics for stereo recording. >>
Sorry Scott, but this is the industry standard... *all* cameras from *all* manufacturers having XLR audio inputs function in precisely this manner. Canon isn't doing anything different or out of the norm at all here.
<< Would there be any way to correct this problem? >>
Well, it really isn't considered a problem. Normally, if you're at a certain production level where you're using professional mono XLR mics, then it generally follows that you're also going to be properly mixing these channels together in the postproduction process... whether it's within a computer-based editing system involving digitized (captured) audio and video, or whether it's done through a sound mixing board in the traditional linear deck-to-deck editing process.
<< What would I do to get both mics on both channels? >>
In the field, you mean? I suppose you could do a couple of things... one would be to employ a small, portable field audio mixer (such as a 3-input, 2-output Shure, about $1000), and feed the output to the MA300. Another idea might be to use two Y-adapter XLR cables. Both mics go into one Y-adapter, choking down to one channel, then out another Y-adapter, branching out to two channels... I'm not sure if this would even work if the mics are of different impedences.
I think your best bet in the long run is to use the adapter as it's intended and follow the standard procedure of mixing channels in post. You'll have a *lot* more creative control this way. Hope this helps,
Old September 21st, 2002, 04:32 PM   #20
Post production audio fix...
Thanks for the info, that helps a lot. You mentioned fixing the "problem" in post production. I use Adobe Premiere 6. How would I seperate the left and right channels off my GL2 in order to put them on my timeline as two seperate audion tracks? If I could seperate left and right channels and then lay them down in the timeline as two seperate audio tracks, this would fix the "problem". Right? Thanks again.
Scott
Old September 21st, 2002, 04:39 PM   #21
You should probably post this question to our PC Editing forum, but as I recall in AP6, if you capture 2-channels of audio, they'll show up on the timeline as two independant channels. In other words, it's done for you automatically. Try posting in the PC forum about this as. Although I have AP6 myself, I generally use the Canopus RexEdit program for most of my editing.
Old September 21st, 2002, 04:43 PM   #22
Thanks. I'll post it in the PC editing forum. I as I see it, in AP6 it imports the audio (both left and right) as one track. I'll see what I get in the PC forum. and thanks sooo much. These forums are wonderful!
Scott Silverman
Shining Star Digital Video Productions
Bay Area, CA
Old September 22nd, 2002, 04:37 PM   #23
Another approach to this problem (if you regard it as such) is to use something like the Studio 1 mic box instead of the Canon adaptor. The Studio 1 box accepts XLR plugs as well as unbalanced inputs, and will accept line level feeds. It also has a switch that puts inputs from both channels into both outputs (a "mono" setting). So if you are taping something that you do not anticipate editing in post, you can do what you want. The box also has attenuators on each input that allow you to balance the relative strength of the inputs in such a situation. It's a pretty flexible little system for $200, and gets the weight of the XLR cables off the camera to boot, if that would be an advantage for you.
No, I don't have any connection to the company, but have just found this box to be well designed, and to perform well for its intended uses, so I thought I'd pass my experience along. It's also nice in that it can be used with any other camera (and even has a ground lift that is allegedly useful with some Sonys).
Linc Kesler
Linc Kesler is offline   Reply With Quote
Old September 23rd, 2002, 11:04 AM   #24
imemine9
Posts: n/a
it was the ma300, and not the gl2 itself.
i bought another ma300 to test it before having to send the whole gl2 in, thank god.
so if anyone has a problem with the two, test the ma300 first. i guess i just got a bum one, it happens....
Old January 11th, 2003, 11:07 PM   #25
DXA-4P vs MA-300
I need to make a decision about which audio adaptor I should purchase for my newly arriving GL2. I will be purchasing a Sennheiser Me66K6 mic very soon, and I am looking for the best way to interface these tools.
I would enjoy reading any related opinions you (anyone) may have.
Thank you for your assistance.
Brad Higerd is offline   Reply With Quote
Old January 12th, 2003, 01:52 AM   #26
Old Boot
Brad - There's been a mass of chat about the MA-300 on this Forum. Can't remember if this included a comparison with the DXA-4P - but have a read anyway - yes?
I'm using the Canon MA-300 in conjunction with a Senni - no complaints yet.
Grazie
Old January 12th, 2003, 03:16 AM   #27
Moderator
I use both. The DXA-4P adds just the right amount of weight to the bottom center "sweet spot" of the camera which some people find that it helps to balance out the camera when you mount a shotgun to the top of the camera, especially if you add a wide-angle adaptor to the front of the lens.
The MA-300 does work quite well though and it "auto senses" whether you are inputting a mic or line level signal.
The DXA-4P can usually also be used on other cameras where the MA-300 will really only work on the GL2.
It comes down to what you prefer I guess.
DONALD BERUBE - noisybrain. Productions, LLC
Director Of Photography/ Producer/ Consultant
http://noisybrain.com/donbio.html
CREATE and NETWORK with http://www.bosfcpug.org
and also http://fcpugnetwork.org
Don Berube is offline   Reply With Quote
Old February 19th, 2003, 11:52 PM   #28
What is the best MINI pre-amp for use with the MA-300?
What is the best MINI pre-amp for use with the MA-300 (XLR inputs)? I have the MA-300 and need a signal boost. I am looking for the SMALLEST battery run XLR compatible preamp.
I'm sure this may have been gone over before, but I was unsuccessful in finding it on the board.
Any product names and links to web sites would be greatly appreciated!
Aaron Rosen is offline   Reply With Quote
Old February 19th, 2003, 11:59 PM   #29
Welcome Aaron
There's a thread running here that will be of interest to you.
Old February 20th, 2003, 12:23 AM   #30
Thanks -
I had read that thread before I posted this. Unless I missed somthing (I have been known to do that), there was no outside links.
I am looking for a few if you have any.
