GL2 / XM2 Frame mode - Page 16 at DVinfo.net
Old November 22nd, 2003, 11:56 AM   #226
Retired DV Info Net Almunus
Hello Alan,
If this instructional video will requre clear stop-action frames then I would certainly shoot in frame mode and use a higher shutter speed, perhaps closer to 1/500 than 1/1000. If it's bright daylight chances are that your iris will still be closed enough to maintain deep DOF.
If possible experiment at the courts before the big day.
Old November 22nd, 2003, 02:23 PM   #227
If I believe your original post and you want the smoothest looking video, then shoot in TV (shutter priority) normal mode and lock that shutter speed down to 1/60th.
Shooting at speeds above about 1/200th sec can result in very stacatto looking footage as so little of the original motion has been captured. Look at it this way: if you shoot at 1/60th you capture everything that happens in front of your lens. Shoot at 1/500th sec and for most of the time the chips are simply waiting around, wondering what to do next.
Slo-mo take your footage and splits it into fields, the better programs interpolating between fields. Action footage shot at 1/500th sec can have an awful lot of information missing and this makes the interpolation difficult (and therefore inaccurate).
tom.
Old November 22nd, 2003, 04:42 PM   #228
Thanks for the input guys. I am going to do some test shooting tomorrow.
This is an ongoing project, so I will be able to get some results and make adjustments. I do need to get the bulk of it shot before the weather goes south on me.
I appreciate the ideas.
Al
Alan Van Vliet is offline   Reply With Quote
Old November 23rd, 2003, 01:55 PM   #229
I shot both in frame mode and normal mode at 1/60 of a second and the quality is definitely better in both modes.
At this point it appears that the best quality is in the normal mode with these settings (i.e. the smoothest playback at regular speed). I have not looked at slow motion yet.
Ken, I understand your point when checking individuals frames, or in effect, stills. In that regard, they are much better at 1/500.
I may be imagining things, but the Auto focus also appears to be "hunting" less in the normal mode at 1/60.
One problem though, at 1/60 of a second I am slightly over-exposing the scene even with the neutral density filter on.
(Zebra patterns on the court lines, white shorts and shoes)
When I hand meter (with an equivalent ISO of 320) I need an aperature of f32, which of course is not available.
I assume I will need an additional external neutral density filter to reduce light ( I usually shoot in bright sunlight) so I can use these settings.
Does anyone know the value of the in camera neutral density filter (so I can adjust and handmeter accordingly)?
Thanks in advance,
Al
Old November 24th, 2003, 02:36 AM   #230
The ND absorbtion is easily checked - and I've done so on my TRV900 and VX. Simply shoot some footage in auto Alan. Use a tripod and something dull and static like a brick wall as a subject. Preferably in the TV mode with the shutter speed locked. Flick in the ND and shoot some more.
Do this on three different subjects and then rewind the tape, push 'display' and check out your aperture readings. Why shoot three different subjects? Simply because the 'display' only reads to the nearest half stop, and you'll be weeding out the tolerances.
The TRV900 often needs an extra ND8 (-three stops) and of course the VX2000 comes fitted at source with internal NDs.
tom.
Old November 24th, 2003, 04:18 AM   #231
Value of ND filter
Tom,
I thought about testing it myself, but I didn't know how to use the display mode to re-read the settings.
Great idea.
Thanks for the input.
AL
Old November 24th, 2003, 08:35 PM   #232
It's "Data Code" on the remote to display shutter, f-stop, and gain.
Tom Voigt is offline   Reply With Quote
Old January 16th, 2004, 03:59 PM   #233
Trying to slow-motion in GL2's frame mode?
I've tried searching through some previous and past topics regarding this discussion, but have found some confusing points. From what I've read, it is very bad to try to slow-motion footage that was shot in the frame mode during post. because it'll create glitches or errors.... The general consensus is that slowmotion-ing something that's already been deinterlaced by the camcorder is bad or the frame/movie mode, specifically, in the GL2? Can anyone clear this confusion up? I don't know if its true...
"Everyone has a photographic memory. Some just don't have film."
David Ho is offline   Reply With Quote
Old January 16th, 2004, 05:53 PM   #234
well, I don't know what they all say, but I shoot in frame mode, shutter speed at 60, variable f-stops depending on lighting and I've taken various clips and and put them in slow motion in post, (adobe after effects_ and they've been perfect.
Rosie Young is offline   Reply With Quote
Old January 18th, 2004, 03:54 PM   #235
I don't have a GL?, but when using Twixtor to do slomo it always turns out better to deinterlace before applying Twixtor. So, I would suspect starting with footage shot in frame mode (non-interlaced) would only put you a step ahead with any software you choose to use.
-Rodger
Rodger Marjama
www.speedwing.net
Rodger Marjama is offline   Reply With Quote
Old January 18th, 2004, 06:41 PM   #236
Hawaiian Shirt Mogul
i shot only frame mode / progressive and don't find slo mo a problem... i've seen others shoot interlace , progressive and their slo mo looks terrible ..IMO comes down to software ...
also depends on how slow you are trying to go ? 50%, 100% , 200< 300% ..above 400% is where you are going to find problems then special software might be needed DEPENDING on the "look" slo mo you are trying to get ...
Don Donatello is offline   Reply With Quote
Old January 19th, 2004, 09:54 PM   #237
It also may depend on how the slomo software renders the slomo sequence. I was wondering about this also.
I've been considering doing a comparison between using frame mode and video mode for slomo effects. What is the preferred program for doing this? I get the feeling that some programs may "cheat" and split and duplicate the interlaced fields into full frames, thereby halving their resolution.
I think I'm going to mess around with an exported sequence in after effects that is interlaced. I'd like to see how it looks at different speeds, particularly when I split and duplicate the fields.
I've used AVID motion effects in the past with frame mode video and if you try to slow the motion down more than about 75% it really becomes unbearably jerky, so I've been looking for a way past this problem.
John Lee
Levelse7en@gmail.com
John Lee is offline   Reply With Quote
Old January 20th, 2004, 07:14 PM   #238
For any who may not have been HERE, you can see some various footage shot with the DVX100. Little bit of a lot of things including, slowmo created from 30p, anamorphic adapter vs letterbox, and some other stuff.
This was all done a while back, but if you've not seen it, it might be worth the time.
BTW, alot of this is full res clips so if you have dial up, you may want to check filesizes before you d/l.
-Rodger
Rodger Marjama
www.speedwing.net
Old January 21st, 2004, 05:14 AM   #239
Tripod + Frame Mode/shutter speed + OIS?
I am going to shoot some shorts on a tripod with frame mode on. Now, the rumors and maybe myths or facts I've heard is that OIS, although different from electronic IS, will still decrease the image quality or resolution by minimal (somewhere around 5-10%?) when turned on. Now, what should be good while using frame mode AND on a tripod? OIS on or off? Of course, I'll be doing extremely slow pans as the frame mode will make things seem jerky if the camera moves too fast.
Next question is what is the best shutter speed setting for frame mode? I, technically, still dont know what shutter speed is all about. All I know is that I have messed around with some settings and it seems that the different shutter speeds with the frame mode on can either reduce or cause even more jerkiness or the laggy effect.. I've tried 1/30 and 1/60 -- those seem to be good, I think.
Old January 21st, 2004, 05:54 AM   #240
OIS does NOT decrease resolution and that`s a fact :)
IF you are using a tripod turn off OIS to avoid any possible problems.
If you`re on NTSC try to use 1/60 shutter for most of the time (1/50 for PAL). This is not a rule, you may choose not to oblige, but it is an advice.
There is an interesting way of improvising steadycam with a tripod and OIS turned on :) I do it all the time... you grab your tripod some ten centimeters beneath the camera (tripods` legs should be retracted) and jump around like a crazy man thinking he has a steadycam ;) ...a happy, crazy man.
Cheers.
Mike Ostracky is offline   Reply
