Apeture changes when zoomed in? at DVinfo.net
Old August 28th, 2002, 04:59 AM   #1
Sorry for the amount of posts from me at the moment but I just keep finding new things. On the XM2(GL2) I was zooming in out, like you do and noticed that when nearly on full zoom the XM2 starts to close the aperture, and if you pull out it will open it up again, why is this? It was in a room lit with just a few lamps so it wasn't exactly bright but nothing that the XM2 couldn't cope with.
Peter B
Peter Butler is offline   Reply With Quote
Old August 28th, 2002, 07:09 AM   #2
Warden
What mode are you using, Green Box, Auto or one of the semi-automatic or manual settings? The auto exposure system (AE) looks at the scene to determine proper lens opening (aperature, F-Stop) and shutter speed for correct exposure. When you zoom the lens, light sources change their size, shape and position relative to the pre zoom settings. The changes may require the AE system to open or close the lens opening to maintain proper exposure. Setting the camera to manual will force the camera to maintain the original lens opening. Of course this may result in the scene becoming too light (over exposed) or too dark (under exposed).
Jeff
Old August 28th, 2002, 07:42 AM   #3
Another reason for this Peter is that the lens is not a constant aperature lens. The max f-stop is f1.6-2.9, which means at the widest focal length the max available aperature is f1.6 and at the longest focal length the max available aperature is f2.9. This increments as you zoom from the widest to the longest.
As you were shooting in low light the zens would have been full open to allow as much light as possible in to the CCDs. The camera will maintain the wide open setting as you zoom but as the f-stop is not constantly f1.6 this will change depending on the focal length.
Adrian Douglas is offline   Reply With Quote
Old August 28th, 2002, 07:51 AM   #4
Cheers guys, Jeff I had it set to manual at 1.6 fstop I'm guessing Adrians right because it changes to 2. something or other when you go to full zoom, you can actually see the picture darken slightly as well. If you then try and put back up to the 1.6fstop while still zoomed in, it won't let you.
Peter B
Old August 28th, 2002, 09:58 AM   #5
This is common for most cameras and camcorders... different aperture values for each end of the lens. They're pretty much all like that.
Old August 28th, 2002, 10:00 AM   #6
Excellent well thats cleared that one up, cheers everyone.
Peter B
