Problem with Title Mix at DVinfo.net
Old October 2nd, 2004, 01:02 PM   #1
Ok here's the problem. I followed Larson's tutorial and created a 2.35:1 mask for my GL2. I had no problem putting the 640x480 *.jpg file on the card from my computer using the usb. I renamed the file USR00001.jpg as instructed. I turn on my camera in CAMERA mode/Tape Mode to get the Title Mix option in my menu. I go to Title Select as instructed and the the blue screen pops up indicating the card is being read. The problem is it never gets past this screen, it just keeps reading the card. Obviously this is very annoying and I'm hoping you guys have a solution. I have a feeling it's a dumb problem with a very simple solution that I'm just not seeing. Any help will be most appreciated because I'm in a real binde.
Imran Jaffery is offline   Reply With Quote
Old October 3rd, 2004, 12:20 PM   #2
Try to go over that tutorial again point by point. I'm not sure what you're missing, but I thought the file needed to be in all caps, such as .JPG instead of .jpg -- you might start over from scratch and see if the problem repeats.
Chris Hurd is offline   Reply
