setup gamma adjustment? at DVinfo.net
Old August 31st, 2004, 04:25 PM   #1
Would changing the setup level on the gl2 so black is not so black lift the gamma a little bit and bring up some of the highlights? I'm just wondering if this control can assist the camera in gaining a little latitude.
Ryan Mattos is offline   Reply With Quote
Old August 31st, 2004, 06:41 PM   #2
Retired DV Info Net Almunus
No. The latitude capabilities on the camera are not variable. Setup level adjustment is a reference adjustment provided to allow compatibility with various broadcast and other presentation equipment. I don't recommend changing it unless you have a specific need to do so.
The solution to the "latitude" problem is to light your scenes carefully and skillfully.
Ken Tanaka is offline   Reply
