Stereo1/16bit flash at DVinfo.net
Old August 24th, 2004, 09:54 PM   #1
Stereo1/16bit flash
I am trying to capture into vegas off of my GL2. The tape plays in the camera, but not on the computer. I have tried other tapes, and they work. With this tape that wont, the camera flashes stereo 1 and 16 bit. Does anyone know what this means or has any suggestions?
Michael Estepp
Mestep@optonline.net
Michael Estepp is offline   Reply With Quote
Old August 24th, 2004, 10:11 PM   #2
correction
Certain tapes play in the camera, and certain ones don't. I don't understand.
Old August 24th, 2004, 11:00 PM   #3
Retired DV Info Net Almunus
What camera was used to record these tapes and what recording mode was used on those tapes?
Old August 26th, 2004, 12:37 AM   #4
The camera used to record these tapes was the Sony PDX10... and come to think of it, I have had this problem before - and capturing off the PDX10 solved the problem - but whats that about? Not sure what speed it was recorded at.
Old August 26th, 2004, 01:20 AM   #5
That you don't know the particulars about how the PDX-10 recorded the tapes is precisely what's biting you in the caboose. Generally, recording in LP mode can lead to playback incompatibilities between cameras and decks. But it's more likely that the tapes may have been recorded in Sony's DVCAM format which is proprietary to Sony cameras and incompatible with your GL2.
Old August 26th, 2004, 09:38 AM   #6
That is terrible... Luckily I still have access to the PDX10... that is mean of Sony...
Thank you for the information
