white balancing? - Page 2 at DVinfo.net
Old July 23rd, 2004, 04:54 AM   #16
Re: white balancing?
<<<-- Originally posted by Jeff Toogood : What do you guys usually use to manually white balance your camera? (cards, paper?? Etc.)
I have a wedding coming up in a few days and just trying to get all the last minute things figured out.
Thanks -->>>
Jeff I found the perfect white balance card for my kit. I was at office depot and found this:
http://www.officedepot.com/ddSKU.do?level=SK&id=460711
The pic doesn't do it absolute justice though. The board is very white and I always WB my GL2 by it. You should definitely check it out, especially if there is an Office Depot near you.
Dennis Parker is offline   Reply With Quote
Old July 23rd, 2004, 05:47 AM   #17
Capt. Quirk
I have a piece of foamcore whiteboard, paid maybe $2 for it. It is in two pieces, around 18x22 each, and hinged together with gaffers tape on one side. I fold this over, and it holds my CT gels. When open, it makes a decent surface to bounce light, and even white balance off of it.
www.SmokeWagonLeather.us
K. Forman is offline   Reply With Quote
Old July 23rd, 2004, 06:12 AM   #18
Old Boot
This I like - I like this!
Graham Bernard is offline   Reply
