Color Gain, Color Phase at DVinfo.net
Old July 19th, 2004, 08:10 AM   #1
Help,
I've been reading some topics on the "push of reds" on the GL2. I see people are adjusting the color gain and phase.....and say when you adjust the Color Gain your adjusting the reds, and Color Phase adjustiong the greens.....is this true.
Color Gain = Red's.
Color Phase = Green's.
Sharpness = I know what that is, its obvious.
Is that all true??
B/C I've noticed on my GL2 the reds are a bit bright, So if I adjust my Color Gain -1 or -2 I'll tone it down a bit (the bright reds)?
Kevin Galliford is offline   Reply With Quote
Old July 19th, 2004, 09:58 AM   #2
Those GL2 controls are the same as the ones on your color TV.
Color Gain = Color level or Intensity
Color Phase = Hue (Green <-> Red)
Ming Dong is offline   Reply With Quote
Old July 19th, 2004, 09:36 PM   #3
keep in mind that these controls are all electronic. i.e., don't expect to push your sharpness and color gain all the way up without the image quality going down.
Daniel Hollister is offline   Reply
