GL2 editing with FCP on Mac at DVinfo.net
Old July 15th, 2004, 10:00 PM   #1
The Canon website says that the GL2 is only compatible with FCP4... has anyone tried using it with FCP3? Are there any problems? What about with iMovie? Any help? Thanks.
Sarah Horrocks is offline   Reply With Quote
Old July 16th, 2004, 06:04 AM   #2
Re: GL2 editing with FCP on Mac
Originally posted by Sarah Horrocks : The Canon website says that the GL2 is only compatible with FCP4... has anyone tried using it with FCP3? Are there any problems? What about with iMovie? Any help? Thanks.
I edited GL2 footages on my iMovie. I don't see why other NLE's can't. A capture is a capture.
Joe Calalang is offline   Reply With Quote
Old July 16th, 2004, 08:01 PM   #3
I use Final Cut Express to edit my GL2's footage & I haven't run into any problems. Good luck Sarah!
Dennis Parker is offline   Reply With Quote
Old July 17th, 2004, 09:43 AM   #4
Thanks so much for the help guys!
Old July 18th, 2004, 03:58 PM   #5
I was going to say I used it, but I really shot footage with a GL2 and then imported it through my sony consumer-camcorder.
Iwouldn't think you'd have any problems though.
Good luck,
Jeff Patnaude
Jeff Patnaude is offline   Reply With Quote
Old July 19th, 2004, 12:52 PM   #6
Works on FCP3 + FCP4.
Chris
Chris Fangio is offline   Reply With Quote
Old July 19th, 2004, 09:33 PM   #7
indeed. i've used my GL-2 which FCP3, 4, and now 4.5HD. why wouldn't it work? it's NTSC DV over FireWire... there's no reason why any camera wouldn't be compatible with any NLE. my guess is that Canon RECOMMENDS the latest version, as any company would.
the only thing FCP3 CANT handle would be the native editing of 24P or HD. but as you are using a GL-2, this has absolutely nothing to do with it.
Daniel Hollister is offline   Reply
