Simultaneously record and output via firewire? at DVinfo.net
Old July 15th, 2004, 07:22 AM   #1
I would like to use the GL2 to simultaneously record while outputting via firewire (to stream the recording live). Can the GL2 do this?
Gary Zimmerman is offline   Reply With Quote
Old July 16th, 2004, 10:56 AM   #2
Retired DV Info Net Almunus
Yes. That's basically how direct-to-disk devices like the Firestores operate.
Old July 16th, 2004, 03:37 PM   #3
You can also output it to a PC that is running a Capture program. I do this with Sony's Vegas Capture.
Jerry: Photography • Video
www.takeonesolutions.com
Jerry Norman is offline   Reply With Quote
Old July 17th, 2004, 12:40 AM   #4
Stop rather than shut down
I found that I had to change the setting so that the camera would stop rather than shut down after not doing anything for a while.
David Yuen is offline   Reply
