Thread Tools
Search this Thread
Digital Video Solution Disk
My disk has been destoyed. Does anyone know how I can go about getting a new one? If I have to go through Canon, how much do they charge for a replacement?
Thanks |
RED Code Chef
What do you use / need the disk for? If it is a driver you can
download it off the Canon site. Software *probably* too. Click here for the GL2's downloads
Rob Lohman, visuar@iname.com DV Info Wrangler & RED Code Chef Join the DV Challenge | Lady X Search DVinfo.net for quick answers | Buy from the best: DVinfo.net sponsors |
Thanks Rob. I downloaded the driver, but as I look through the manual, I notice that it says to hook the camera up to your computer before installing. However, it says Do Not hook the camera up before installing the solution disk.
RED Code Chef
USB equipment needs the driver installed BEFORE you attach
the device in 9 out of the 10 cases. So if it comes with a setup program run that before you attach the device. If it doesn't then it is probably just a driver disk and you need to point Windows to it when it asks for a drivers disk when you attach such a device. If you have a setup and did not run it before attaching the device go into your control panel and then down to system. Go to the Hardware tab and then click on Device Manager. Your device should be listed probably under unknown devices. Remove it from the list (device should NOT be attached to the computer) and reboot to be safe. Then run setup and after it is done plug in the USB device.
