Did I kill my GL2? at DVinfo.net
Old June 29th, 2004, 09:59 PM   #1
Did I kill my GL2?
I was not aware that my 6 year old had spilled diet pop on my battery charger, Canon Compact Power Adapter CA-920,
When I pluged my GL2 into it the camera made a strange noise and stopped working, it will not even work with a battery. I notice that the charger has a burn electric wire smell to it.
I can replace the charger cheap, but my question is how much damage may have been done to my GL2. Anyone else ever experience something like this?
Thanks for your help everyone.
Thomas Fraser is offline   Reply With Quote
Old June 29th, 2004, 10:15 PM   #2
Retired DV Info Net Almunus
It sure sounds like you've at least blown some internal micro-fuse in the GL2. Hopefully, it's not worse than that although the fact that you heard a "strange sound" does not bode well.
This is not something you'll be able to repair for yourself. Contact Canon Service.
Old June 30th, 2004, 09:28 AM   #3
Removing tape?
Is there anyway to remove the DV tape from my dead GL2 before sending it in for repair?
I don't want them to lose my vacation tape that's in camera.
Old June 30th, 2004, 01:28 PM   #4
None that I know of. Better to let them extricate the tape. Just make sure they know it's in there.
Old June 30th, 2004, 08:50 PM   #5
Just a chance. Remove the internal watch battery from the Gl2 and let stand for 2 hours and replace battery with new one. Put battery in and turn on. Im wondering if you tripped some circuit and by removing the battery, you reset the breaker...if there is one. Give it a try, you have nothing else to loose.
Joe Cirino is offline   Reply With Quote
Old July 15th, 2004, 05:52 PM   #6
Killed but fixable
It turns out that the charger burned up and sent a sergwe to the camera(GL2). It burned out one of the boards inside. I have to pay $285.00 to fix the cam and $59.00 for a new charger. In light of the fact that the charger killed my camera should I ask Canon to cover my costs of repair and replacement of charger, the warranty had expired by 4 months.
P.S. Thanks to everyone for your input and ideas.
Old July 15th, 2004, 06:08 PM   #7
Warden
Warranties only cover manufacture's defects in materials and workmanship. Acts of God and 6 year olds are not covered.
Jeff Donald
Carpe Diem
Jeff Donald is offline   Reply
