Which Firewire Cable for a PowerBook G4 at DVinfo.net
Old July 23rd, 2002, 02:01 PM   #1
Hi,
I just got a GL2 and want to hook it up to my PowerBook G4 using a firewire cable.
The Canon site shows two:
http://canondv.com/gl2/a_cables.html
Which one do I use?
4 to 4 pin ot 4 to 6 pin?
--Steve
Steve Garfield is offline   Reply With Quote
Old July 23rd, 2002, 05:09 PM   #2
Warden
The 4 to 6 pin.
Jeff
Old July 23rd, 2002, 06:05 PM   #3
Retired DV Info Net Almunus
Steve,
You might find a bit more info useful. A "6-pin" Firewire connector is basically rectangular with one rounded end. A "4-pin" connector is also rectangular but noticeably smaller and features a dimple on one side of the rectangle. The extra 2 pins of the 6-pin connector enable it to carry currrent from the computer's bus to bus-powered devices (such as some hard disks). Since your GL2 only sends signal to the computer it only takes a 4-pin cable/connector.
Old July 23rd, 2002, 06:23 PM   #4
Ok.
Thanks for the help.
This forum is great!
--Steve
Old July 23rd, 2002, 06:59 PM   #5
And your Mac has the 6 pin on it as a standard... it's the same size as the one on your iPod. :-)
Joshua Wachs is offline   Reply With Quote
Old July 24th, 2002, 09:48 AM   #6
Firewire cable works nicely
I got the Firewire cable over at Microcenter for $4.08.
Works nicely.
Thanks.
