Help, Lense hood GL2 at DVinfo.net
Old June 19th, 2004, 08:43 AM   #1
Hey can anyone please help me? The Sony DCR-VX2100, the lense hood on it, I like it alot better than the one that came with my GL2, just looks more agressive. So I went to sony's websight and did a 360 degree view of the camcorder and you can make the lense hood come off, and the attachments look identical to the GL2.
I just orderd it thru sony, its the same diamater lens also 58mm just like the GL2.
Has anyone ever tried this? I think it will fit, but not 100% sure.
Let me know thanks!
Kevin
Kevin Galliford is offline   Reply With Quote
Old June 19th, 2004, 10:06 AM   #2
No never tried or heard of anyone trying. If you like the aggressive look hows about sticking some white tooth shaped bits of plastic around the box, like teeth, and making an adaptor so you can use 2 of the clip on g3 lights, like eyes. As soon as you point your camera at anyone in the dark, they will cover their face and run.
(sorry for taking the mick but its my birth right!)
StMichael
Michael Connor is offline   Reply With Quote
Old June 19th, 2004, 10:19 AM   #3
Hahhaaha,
verry funny, that was a good one though, thanks man!
-Keivn ;-)
Old June 19th, 2004, 01:22 PM   #4
I own a XM2 and i have tried it with the lens hood of my friends VX2100. It does not fit.
Bernd
Bernd
Bernd Binder is offline   Reply With Quote
Old June 19th, 2004, 10:39 PM   #5
Old Boot
"Cap 'n Fiddle"
The Lens cap "fiddle" is one of the main things I really detest about my cammie. Canon hasn't got it right .. they will most likely NOT get it right in an XM3 either!
Grazie
Graham Bernard is offline   Reply
