Filters at DVinfo.net
Old June 15th, 2004, 10:10 PM   #1
Filters
Which filters would make for a good set for all around use? For that matter which filters are in your kit?
Alex T. Hurter is offline   Reply With Quote
Old June 15th, 2004, 10:18 PM   #2
Retired DV Info Net Almunus
Alex,
We have 157 threads dealing with filters[/url] in this section alone. So there's already plenty for you to read.
In general, a good polarizer and a protective do-nothing filter such as a UV are the basic staples. You might also want to add a neutral density filter to supplement your single-stage onboard ND filter.
There are dozens of special effects filters that can be useful, too.
Old June 15th, 2004, 10:23 PM   #3
Thanks Ken. I was not aware of the "search" feature on this message board. I'll use it in the future.
Old July 21st, 2004, 06:06 PM   #4
Hey Ken, did the link change for the 157
threads on filters? I clicked on it and it was dead
Old July 21st, 2004, 09:35 PM   #5
The link pointed to the results of a Search, which apparently dissolves over time.
To reproduce the results just re-run a Search on "filter".
Old July 22nd, 2004, 05:51 AM   #6
Steven Davis is offline   Reply
