VL3 vs. VL10i lighting at DVinfo.net
Old June 15th, 2004, 08:05 PM   #1
Can someone point me to the VL10i power source so I know what I'll need. If I understand this correctly, the VL3 uses the camera's battery while the 10 requires an external power source...do I have that correct?
Kyle Field is offline   Reply With Quote
Old June 15th, 2004, 08:14 PM   #2
it uses a battery
you simply slide one of your extra camera batteries onto the back of the light. it's not powered from the shoe like the vl3.
Hank Freeman is offline   Reply With Quote
Old June 16th, 2004, 12:58 AM   #3
Thank you!
