Halo at blue/red interface? at DVinfo.net
Old June 14th, 2004, 12:56 PM   #1
Here is a short clip of some video I shot at the Olympic Trials (for Judo). If you look at the interface between the athletes blue gi (uniform) and the red mat, you will see what appears to be a halo? (pausing the video helps). Is this normal for the GL2?
Ming
Ming Dong is offline   Reply With Quote
Old June 14th, 2004, 01:04 PM   #2
Retired DV Info Net Almunus
Red tends to be a messy color for Canon camera. Still, part of what I see is due to compression. Part appears to be actual reflection from the red to the blue.
Old June 14th, 2004, 01:09 PM   #3
Warden
Where is the clip? Your link is to the main page of a web site.
Jeff Donald
Carpe Diem
Old June 14th, 2004, 01:14 PM   #4
<<<-- Originally posted by Jeff Donald : Where is the clip? Your link is to the main page of a web site. -->>>
It is an mpeg1, so should play on any computer. When I click the link, it opens a new IE window and plays the video. Not sure why your seeing a website instead. Try it again?
Old June 14th, 2004, 01:28 PM   #5
Warden
Ah, your web site is not Mac friendly, so I probably won't be able to help as much. Usually red, blue dispersion is the result of lateral chromatic aberration. See Number 5 in this article on DV Info.
Jeff Donald
Carpe Diem
