#511 |
I record timelapse footage straight into my laptop with no tape..had the power supply connected..worked fine, but I think the camera being connected to the computer via the firewire overrides the camera fallin "asleep." Do you have access to a laptop by any chance? that's probably ur best bet..capture straight into NLE..and you could edit if needed or just burn onto dvd from there..
#512 |
tapeless..
You don't need a tape to accomplish what you're saying. Eject any tape. Run the AV cable into the DVD Recorder, the camera won't power down.
You can still do it off of battery and you can still do it with the tape door shut, as long as there's no tape inside. I've done it many times. |
#513 |
Canon GL1 & GL1a
What is the differnce between the Canon GL1 & GL1a?
I'm new to this site as you can tell My grandmother gave me this video camera that I hardly ever use. So I think I might get rid of it but I'm not sure if it's the GL1 or GL1a. |
#514 |
There was no such thing as a GL1a. There was only the GL1.
Are you sure you're not asking about the difference between the GL1 and GL2? There's a world of difference between these two camcorders. So much changed going from the GL1 to the GL2 that it's a lot easier to tell you how they're the same rather than how they're different. How they're the same: Both have a 20x zoom lens, optical image stabilization and Frame movie mode. Everything else between them is different. |
#515 |
Within the XL line, the DM-XL1A was the North American (NTSC) version
The letter "E" was used to designate the European (PAL) version; e.g., DM-XL1E. The NTSC version of the HV20 is labeled HV20A, and the PAL version is HV20E. FWIW: The Canon L2A was the NTSC version of the L2, and the old A1DigitalA (going back to to 1991) was the NTSC version. I've not seen the "A" designation used in the the GL1 literature (owners manual or service manual), because the PAL variants have a designation (i.e., XM1). However, that nomenclature (DM-GL1A) is retained on the nameplate of the NTSC version of the camcorder. Thus we can assume with some measure of confidence that the GL1A is just the North American (NTSC) version of the GL1.
dpalomaki@dspalomaki.com |
#516 |
Now that I did not know. I learn something from you just about every time you post, Don -- many thanks,
#517 |
Okay. I have the GL1 then.
On the botem of the camera it has GL1a, but on the side it has GL1. Thanks for the help. |
#518 |
Can GL1 be used as webcam?
Obviously, there is no USB interface. Is there a way to allow it to operate as a webcam? I do a daily internet video program, and I own a GL1. I currently use a Panasonic sdr s150 as a webcam. Any help would be appreciated. Thanks
Marc |
#519 |
I have used my Canon XM2 as a webcam several times. So I believe you should be able to use the GL1 too. (you will have to use firewire)
#520 |
I use 35mm as webcam. Really, works great, I get no complaints from my chat-partners!
only kidding, I think you should have no problem using the GL1 as a webcam, if the program and your computer recognizes it. |
#521 |
My GL1 is running the demo when a webcam
I plugged in the firewire, and my video app recognizes the cam. However, the camera goes into an auto demo mode, zooming, slimming and stretching.
How do I kill the GL1 demo? I am running a daily internet TV program, and really want to use this camera! Thanks. Marc |
#522 |
Camera Menu > Demo Mode > Off.
As described on page 23 of the GL1 operator's manual. |
#523 |
best tape for a gl1
Hi everybody, I just got a used gl1 and now I'm confused about which brand of tapes should use,
the person that owned this camera recommended panasonic but as I have seen various types and prices I don't know which will be the best for this camera so the thing is, does getting the expensive ones makes a difference? or it's is ok to get the cheaper? also which is the one You use (if you have a gl1)? and where you buy them, I think most of us (if not all) look for the best prices. |
#524 |
The GL1 is a great camera to get started with, especially if you picked up for a good price. Stay with Panasonic brand there is nothing wrong with them and it is always best to stay with the same brand.
I pick my tapes up at thetapguys.com. Fair price and good service. Since your still shooting standard def, I would suggest saving the money get their middle grade tape. Chad |
#525 |
No Start Up on GL1
Went to turn on my GL1 and nothing happens. It was working absolutely fine a couple hours earlier. Batteries are all good. I hit the reset button to no avail. Wondering if there's a backup battery inside that would prohibit the camera from turning on. If there is a b/u battery how do you get access to it and what type of battery is it that I'd need to replace. Any thoughts are greatly appreciated.
