Your comments on the Schriber 568 w/ Canon GL-2 at DVinfo.net
Old May 21st, 2004, 07:53 AM   #1
Guest
Posts: n/a
I'm doing some microphone comparisons for the GL-2. I need something which
has a longer distance than the on-board mic, has a wide enough pick up pattern for two or three people if necessary, and has pretty good sound quality for documentary videography.
If you are using the Schriber 568 with a GL-2, I'd appreciate your input.
Dan
Old May 21st, 2004, 03:34 PM   #2
I had the Schriber 568 shotgun mic but there were a few things I did't like - so I returned it in favor of a Sinn ME66.
What I liked:
Price
What I didn't like:
Weight (Heavy)
On/Off switch (too easy to operate - easy to turn on inadvertently)
Hiss - Level of hiss on long range setting unacceptable - short range OK.
Hope this helps - HAVE A GREAT DAY!
dave b.
David Billingsley is offline   Reply With Quote
Old May 22nd, 2004, 09:07 AM   #3
Guest
Posts: n/a
ME66
Thanks for your input Dave.
How do you like the ME66? Do you use this with the GL-2?
Does it have an omni and super-cardoid option?
Dan
Old May 22nd, 2004, 06:33 PM   #4
ME66
I like the ME66 and yes it is being used with a GL-2.
How I use it:
1) On camera via LightWave mount and Sign Video Adapter (ME66 is XLR)
2) On boom via 25' XLR cable to Sign Video Adapter to GL-2.
3) On Boom via 25' XLR cable to Sound Device 302 field mixer to Sign Video Adapter to GL-2. Sometimes I include a SENN Evol 500 wireless mic via the SD 302 mixer also.
Remember - if you want to go to a PRO mic you will need a XLR adapter to interface to the GL-2 Mini stereo mic input. Two good brands are BeachTec and Sign Video. The ME66 mic out is hot and the adapter lets you control the mic output going to the GL-2.
The ME66 is a set length mono shotgun mic. The XLR adapters allow you to take a mono mic output and send it to both right and left channels on your GL-2.
This setup has worked very well for me. I have done some documentries containing lengthly interviews and the ME66 on a boom works great. (This is a retirement hobby)
Any good pro mic will give much better results than the GL-2 mic. The closer the mic is to the source - the better - very important.
I would recommend purchasing Jay Rose's book - "Producing Great Sound for Digital Video". It will be a great help in learning to capture better sound - which is much more difficult than video.
There are many good pro mics available - the ME66 is in the good bang for the buck class ($400). You can go as high as the $1400 range.
Hope this helps - HAVE A GREAT DAY - dave b.
Old May 23rd, 2004, 12:09 AM   #5
Guest
Posts: n/a
Thanks David. Extremely informative and very detailed.
Dan
Old June 8th, 2004, 12:40 AM   #6
Dan,
I have the Schriber and its an OK mic, but really only OK. Like dave said...this sucker is heavy and the on-off switch has decided to sneak to the off position a few times on its own. And the HISS...the neverending hiss.
Overall, I would say that if you are going to do any serious work, you gotta move up in the mic world a bit.
I bought the Audio Technica 897 (from DVinfo.net sponsor "Zotzdigital") and I love it. It is light, no on-off switch, and the sound is very crisp.
I use the Sign Video XLR-PRO adapter with it.
Hope this helps, better late than never.
Mustafa Davis is offline   Reply With Quote
Old June 10th, 2004, 09:58 AM   #7
I went through two of the Schreibers before getting the Sennheiser. The hiss of the Schreibers was really annoying. I talked to one of their engineers and they said it was news to them. However, an internet search shows that it is not that uncommon of a complaint....
Jeff Price
Flickerflix Nature Videos
flickerflix@yahoo.com
Jeff Price is offline   Reply
