What Does a Wide-Angle Do When Zoomed? at DVinfo.net
Old April 12th, 2004, 07:18 PM   #1
hi all what does wide angle do when zoomed? does irt give a 16:9 feel?
i'm ultra newb
8)
Charles Bittner is offline   Reply With Quote
Old April 12th, 2004, 08:57 PM   #2
Retired DV Info Net Almunus
I assume you mean a wide-angle adapter lens, like the WD-58. No, it doesn't change the aspect ratio of the frame. It simply reduces the effective focal length of the lens. That is, your frame is not quite as tight when zoomed in.
Old April 13th, 2004, 06:36 PM   #3
bingo, wd-58, could someone point me to a comparison picture with and without wd-58
Old April 14th, 2004, 04:55 PM   #4
The image at:
http://www.centuryoptics.com/products/dv/65x_wa/65x.htm
will give you a general idea, although it is a 0.65 not a 0.7 so it is a bit wider.
dpalomaki@dspalomaki.com
Don Palomaki is offline   Reply
