Need input on the DM-50 Directional Mic - Page 3 at DVinfo.net
Old February 24th, 2003, 12:17 PM   #31
I think the ecm-ms957 is the updated version of ecm-s959c with some little difference.
In the 959 type, there isn't the mid side feature and the cannon plug in but for the other i think it's pretty the same.
Giampy
Giampy Car is offline   Reply With Quote
Old May 7th, 2003, 10:27 PM   #32
Furry mic muff for DM-50?
Anyone know if there is one?
Joe Lloyd is offline   Reply With Quote
Old May 8th, 2003, 07:30 AM   #33
I don't think so.
Ask the folks at www.mikemuff.com if they can make you one. They seem to be coming on fast and strong; although the item is not in their list, they might be interested.
Better yet, maybe one of their existing models will fit well enough to be useful. They have three models so far, with five more coming. The current models are a mere $40.
I should also mention www.lightwavesystems.com. They have nothing specifically designed for the DM-50 but there are some products that might fit, like the Miniscreen. Light Wave products are extremely expensive. The Canon GL2 EQ-GL is $150 compared to MikeMuff's $40.
Will Fastie is offline   Reply With Quote
Old May 9th, 2003, 08:53 PM   #34
Anybody ever go to Walmart get the faux fur and make their own mic cover?
Ron Little is offline   Reply With Quote
Old May 27th, 2003, 06:09 AM   #35
How good or bad is the Canon dm-50?
Looking for some information on the Canon dm-50 shotgun mic. Anyone out there with any thoughts? I shoot outdoor videos, fishing, hunting, hiking etc. The price seems pretty reasonable but what about the quality? Any help would be greatly appreciated!
Rick
Rick Forge is offline   Reply With Quote
Old May 27th, 2003, 06:23 AM   #36
One other question: can the dm-50 be used without the powered shoe mount ( If I already am using the MA300 which has a shotgun mic holder)?
Rick
Old May 27th, 2003, 09:19 AM   #37
Outer Circle
I've used it. I think it's pretty good, for the the money.
Old May 27th, 2003, 09:56 AM   #38
<<<-- Originally posted by Rick Forge : One other question: can the dm-50 be used without the powered shoe mount ( If I already am using the MA300 which has a shotgun mic holder)? -->>>
I don't think the dm-50 will work without the smart shoe on the GL2 or ZR-50, ZR-70, etc. Talking with Brian at Zotz Digital, he recommends the Schriber 568 over the DM-50. With a shock mount, you are $5 more than the DM-50. This should give you much better sound than the DM-50. This can also be used on any camera with a 3.5mm mic input and a hotshot physical mount. My only question is to get this or spend a little more for a better mic.
Joe Sacher is offline   Reply With Quote
Old May 27th, 2003, 10:17 PM   #39
A Vote For the DM-50
I shoot opera's using the DM-50 and my clients like the sound.
But I haven't used other microphones so I can't make a direct comparison.
The advantages of the DM-50 as I see it:
- It's STEREO. At Digital Verite' they have played my stuff over a projector system with a really good amp and speakers. The stereo picture is amazing. You can hear the shape of the room. That person that coughed? You know exactly where he was sitting.
- It's convenient and safe. Stick it in the hotshoe and forget it. I don't monitor sound, and I have never failed to get good results. It uses the camera's automatic level controls so you can't screw up and set the wrong levelsl, or turn it off by mistake. It won't come unplugged. (In fact in the GL2 it takes a real strong pull to get the thing out of the hot shoe.)
- It does a good job on acoustic instruments and voice (operas, remember). If the sound is good from where you are shooting from, it will sound good on the tape. It is reasonably directional, so it doesn't magnify my shuffling about, coughs and handling noise.
I doubt if it is perfect, but it is some of the best money I have spent.
-Tom-
Tom Voigt is offline   Reply With Quote
Old May 28th, 2003, 06:16 AM   #40
Thanks Tom! For the money I might give it a try. One other question- If I use the dm50 in the hot shoe can I still use an xlr adaptor (beachtek) for my lavaliers? Can I still use 2 wireless lavaliers in addition to the shotgun? Or do I have to disconnect the shotgun from the hot shoe?
Rick
Old May 29th, 2003, 12:32 AM   #41
The *only* way the DM-50 works, is through the electrical contacts in the advanced accessory shoe.
The GL2 is limited to two channels of live audio recording, so you'll have to choose either the DM-50 via hot shoe, or your Beachtek XLR adapter via the red 1/8" stereo mini plug on the side of the GL2.
Old September 16th, 2003, 02:01 PM   #42
Do you have DM-50?
A question for you who use Canon microphone DM-50.
Do you like it?
How much better is it compared to the camcordermic.?
PLease tell me your experience with DM-50, because I wonder if I shall buy it.
"The artist is nothing without the gift, but the gift is nothing without work."
Torsten Blomfeldt is offline   Reply With Quote
Old September 18th, 2003, 07:05 PM   #43
I Just got one. Not bad, but hey, its cheap, and its better than whats onboard if your on a budget. Nice though...
Joe Cirino is offline   Reply With Quote
Old September 18th, 2003, 11:48 PM   #44
tell me more
Please tell me more when you have tested it thoroughly.
Is it much better than the camcorder mic?
For instance, when it is windy, how do DM-50 handle it?
Old September 22nd, 2003, 12:16 AM   #45
It's pretty decent. It handles the wind better than the onboard mic, but it will stick pick it up. Plus you have 3 modes to choose from -- the shotgun, stereo 1 and stereo 2. Like the previous post mentioned, it's a good value. It uses the hot shoe so there are no wires to deal with. Otherwise, youd have to find a mic that uses the mic jack, or use an XLR adapter which i think costs more than the DM-50 itself.
Andrew Fu is offline   Reply
