2nd tally lamp at DVinfo.net
Old March 7th, 2004, 12:11 PM   #1
2nd tally lamp
Is there any possible way to create a second tally lamp for the GL2? A second one mouted on the hot shoe would be ideal.
I keep a wind sock on the microphone, and cannot really see the record pause designation in the viewfinder or LCD screen when I am filming (while skiing in bright light with goggles or sunglasses on). I use the LCD to just basically frame the subject which in bright light or while it is snowing is also difficult.
My previous camera had a tally light on the front and back so I always knew when the camera was recording. I've missed a few shots I really wanted to capture and have had the camera inadvertantly recording when I did not know it was several times the past few weeks.
thanks for any suggestions.
Frank
Frank Chang is offline   Reply
